The 10" plays perfectly this morning -- and I'm sure the customer will abuse test it well :)
I may end up needing stiffer packs for him but I think this will do nicely based on what Derrick did to a 12" with this pack in his explorer.
is that coil a normal stock item for you?
and do you sell loose soft parts?
i may need too contact you later on if you do.
It is a stock NS v.2 coil -- so yes we have it.
We sell certain parts but not all of them.
  • 3 weeks later...
that is a monster 10 drooling over this sub :lol2:
  • 5 months later...
I am building a set of like these on Z v.3 motors with the NS v.3 spider stiffness / the Z v.3 tall roll surround (re-building customer 15s into 10s) :
* Dust cap isn't glued yet; just chilling out for now but that is how it will look.
* Yellow NS v.3 spider
* The terminal tabs are bent just right so the leads won't hit the cone or the adapter. Also put a small piece of tape across the adapter as an insulator just in case they do happen to get bent for some reason. As these are one of a total of five of these ever made and only a total of ~40 or so planned I don't have anything fancy for an insulator and just use a bit of tape (I have also yet to see the leads get bent down as they are oriented very carefully). A few people asked me about it so I am explaining in detail :)
