KNU sells similar ones that I have used in the past!
http://www.knukonceptz.com/productDetail.cfm?prodID=SSRT0
the only down side to them is the hole in the center is about 5/16 (0.31252") and i believe they are about 0.25 thick, so you will need a longer screw! so if you are using one of those big D3100 batteries that have a 3/8 hole you will have to some how drill that bigger!
if you are against crimping on terminals then these are the answer!
I would recommend getting some simpler terminals that you can solder if you are going for performance. I could see those thing being hard to work with
what kind of buss bar are you looking for? Ramrod and I make them at my work. pm me with details and such.
Well those terminals were mainly for on the batteries.
My plan. And I hope I describe this correctly. Is to have a board with a seriesof bolts with fuses attaching to another series of bolts. Have the battery connections on one side and the run from the front going to a buss bar attacheched to the other bolts. As for my fuse holder.
The plan is to have 2 optima yellow tops and 3 d3100s in the wheel well of my Xb. So I can't just line them up.
sounds crazy,,, I love it! lol! wait Xb,? scion? I think another member on here has one of those... Shizzzon I think has one!
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=263-683&scqty=10
Does anyone have experiance with these? And how secure are they?
And is there anyone that makes buss bars on here. I think I remember someone a few years ago ofeering this service but I could be wrong.
I use P3 RCA connectors. I bought about 30 of them over the year. Quality control is great and the connector looks great.
I would expect a good product with any P3 connector. Cost wise - midline.
surely you aren't talking about these?
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=263-212
I will be using something like this i drew out for my scion tC-
Does this spark some interest?
dude epic movie/clip! nicely done!
No doubt man. They work great. If you have a problem with them then you f'd up!
That does like nice shizzon bit I feel that may be more than I need. Mine would really only need like 6 bolt holes in a line.
Btw where were you planning on placing that.
oh i know, hehe, just showin what all i planned on doing..
I'm building a wall and the battery bank will be right behind it.
I'm thinking about either mounting it on top of the wall(it angles down with the hatch),
or attach it to the back part of the wall.
