Posted December 1, 201114 yr I just received my ssd 18"s and they look sweet.....thankyou. Well my question is......I ordered dual 1ohm coils so I could wire each of them up for a 2ohm load....any idea how to do that??? I am using them for hometheater and hooking them up to a behringer ep2500----its 2 channels @ 2ohm per channel @ 1200w. thanks email is [email protected]I think its supposed to be....... terminal 1....positive to amp--- terminal 2....neg to amp--- jumper between left over neg and pos........ Is this correct???? thanks Edited December 1, 201114 yr by rich 1
December 1, 201114 yr Author Ok good, I was right. Pictures make what I was trying to say much easier. thanks
December 1, 201114 yr I just received my ssd 18"s and they look sweet.....thankyou. Well my question is......I ordered dual 1ohm coils so I could wire each of them up for a 2ohm load....any idea how to do that??? I am using them for hometheater and hooking them up to a behringer ep2500----its 2 channels @ 2ohm per channel @ 1200w. thanks email is [email protected]I think its supposed to be....... terminal 1....positive to amp--- terminal 2....neg to amp--- jumper between left over neg and pos........ Is this correct???? thanksYou should make a build log. A 18" in a ht setup sounds prety interesting
December 2, 201114 yr Author http://www.hometheatershack.com/forums/ported-subwoofer-build-projects/50656-where-can-i-buy-18-subwoofer.htmlallready did.......lol
December 2, 201114 yr Nice to see you over here.Series your coils on each sub to give 2 ohms on each sub.
