Posted December 22, 201113 yr Hey, what would be an appropriate ported box and port length for 2 Dcon d4 12"s. I have ~ 1000 watts coming from a Rockford Fosgate 1051s. I did see the boxes listed in the tech section. I just wanted to make sure I read it correctly.
December 22, 201113 yr If the listed box sizes work I would recommend going with that design. Port size and length will be accurate.
December 22, 201113 yr Admin http://www.soundsolutionsaudio.com/index.php/downloads/enclosure-designs/item/12-dual-ported-32-ft3.html?category_id=23
December 22, 201113 yr Author System will be going into a 1983 Cutlass Supreme, cousin to the more popular Buick Grand National and Monte Carlo SS. Head unit is a Kenwood x994. Front stage Focal 165 v 30 bi-amped. Mids/highs amp (2) RF Power 551s. Subwoofers (possibly 2 x 12" Dcons). Sub amp is a RF Power 1051s. If there is anything else you guys need let me know. I wasn't sure if having more than rated power would make the box specs change. ~ 1100 watts for the pair???
December 22, 201113 yr System will be going into a 1983 Cutlass Supreme, cousin to the more popular Buick Grand National and Monte Carlo SS. Head unit is a Kenwood x994. Front stage Focal 165 v 30 bi-amped. Mids/highs amp (2) RF Power 551s. Subwoofers (possibly 2 x 12" Dcons). Sub amp is a RF Power 1051s. If there is anything else you guys need let me know. I wasn't sure if having more than rated power would make the box specs change. ~ 1100 watts for the pair???If you use dcons you only need 600 wrms total.
December 22, 201113 yr System will be going into a 1983 Cutlass Supreme, cousin to the more popular Buick Grand National and Monte Carlo SS. Head unit is a Kenwood x994. Front stage Focal 165 v 30 bi-amped. Mids/highs amp (2) RF Power 551s. Subwoofers (possibly 2 x 12" Dcons). Sub amp is a RF Power 1051s. If there is anything else you guys need let me know. I wasn't sure if having more than rated power would make the box specs change. ~ 1100 watts for the pair???If you plan to throw 1100 at the pair (would'nt recommend it) id shrink the box a bit, but it seems to me that that power would be better suited for either SA-12s or Obsidian 12s, or even skars. I don't think youll benefit much by by doubling the Dcons rms.
