Posted December 26, 201114 yr i have 97 gmc yukon and i was wondering if anyone know where to get a good high output alternator for under 300. i would like it to be 250 amps
December 26, 201114 yr i got mine for around that price new, i did a load test and a 240 amp alt was proven to be 238 ( the most load i could present at the time)
December 26, 201114 yr Author i got mine for around that price new, i did a load test and a 240 amp alt was proven to be 238 ( the most load i could present at the time)where did you find it at?
December 26, 201114 yr Look used at alts or mechman has a few closeout alts for sale, a 250 amp for 299 and 200 amp alts for 199
January 5, 201214 yr I have I also cut the cord for the knob that adjusts the voltage, I wanted to be able to change voltage without having to get out the car.Ive noticed a few that dont work out like my tahoe for one.
January 5, 201214 yr I have I also cut the cord for the knob that adjusts the voltage, I wanted to be able to change voltage without having to get out the car.Ive noticed a few that dont work out like my tahoe for one.what?
January 6, 201214 yr You can add a variable resistor on one of the sensing leads of the alt to raise the voltage. Not all work like that however,
