Howzit going guys, I had a question on how much power would i need for "daily use" . I dont care about db levels or that kind of stuff, just something fun to listen too. I was wondering if 700watts would be good for a fun daily system
need more info.
Give us as much info on the sub as possible, and amp if possible.
Is it the dual 2 ohm or the dual 4 ohms sa-10?
Is that 700 watts rms or peak? and at what ohm?
need more info.
Its the dual 4 sa-10, and the amp is a Soundstream stealth 1200D. The amp is rated at 700wrms at 2ohms
need more info.
Should match well.
Thanks, i was thinking of going with 900watts but i think that will be a bit much
need more info.
Should match well.
:fing34:
You wouldn't really notice much of a difference in terms of loudness from 700watts to 900watts; however, that doesn't mean switching amps in general will not change the sound or loudness.
ohh ok, Thanks for the help guys :thanx:
