May 30, 201313 yr For those wondering, here is the setting of my amp.why is gain all the way to six volts?A better question is: how do you know it's set to 6v?Looks like it from this angle. My deepest apologies
May 30, 201313 yr For those wondering, here is the setting of my amp.why is gain all the way to six volts?A better question is: how do you know it's set to 6v?Looks like it from this angle. My deepest apologiesConsidering the gain adjustment likely exceeds 360 degrees it's hard to know. Oh and no need for apology, I'm just being a smart ass. Edited May 30, 201313 yr by stefanhinote
May 30, 201313 yr For those wondering, here is the setting of my amp.why is gain all the way to six volts?A better question is: how do you know it's set to 6v?Looks like it from this angle. My deepest apologiesConsidering the gain adjustment likely exceeds 360 degrees it's hard to know. Oh and no need for apology, I'm just being a smart ass. I had a hunch lol
May 31, 201313 yr Imma go out on a limb and say it's not at the 6volt position and at the 3/4 position instead.
June 1, 201313 yr Author It's at a little less than 3/4. No processing in between amp and h.u. and bass level at zero. It's set this way because that's where its the loudest.
June 1, 201313 yr It's at a little less than 3/4. No processing in between amp and h.u. and bass level at zero. It's set this way because that's where its clipping the most Fixes
July 4, 201313 yr Shit's still gonna be weak! You wait until I finish this box. I'mma light up these tensil leads and start a fire! Shh don't tell anybody what sub.
July 4, 201313 yr Author Shit's still gonna be weak! You wait until I finish this box. I'mma light up these tensil leads and start a fire! Shh don't tell anybody what sub.
July 7, 201313 yr Author Why in the hell did you do that? Well my thought process was that, that's the first layer the air hits, so if I make that part as strong as possible, then it would be most effective. Also picked up the idea from PWK.
July 7, 201313 yr it will help it from moving what you should have done is get MLV and put it there.. it will stop the rattle and really help... my doors have the stick and peal kinda second skin and also a blanket of the MLV between the door panel and the door skin
July 8, 201313 yr Admin I had to do the same on my front doors, the AA carbon's were just vibrating the door card enough that it was entering into the sound.
