Posted February 8, 201214 yr Hello.I am from Russia and my English is very bad... I want to ask for you the help. I have 2 subwoofers sa-10, and to build a box I be not able. You couldn't throw off the drawing of a box for these subwoofers with adjustment 33-35Hz.Help me please.
February 8, 201214 yr Hey Nikita, I just got through designing an enclosure for two SA-10s yesterday, and don't mind sharing that with you. Specs are as follows:External Dimensions DWH = 17.25"x29.25"x15.5"Net volume for Sub = 2.2 Cubic feetPort length = About 38"Tuning Frequency = 34 HzThis is using an L shaped slot port. The internal dimensions of the woofer chamber is 12"x24"x14". The port is 3" wide, and 14" tall. I can send you a picture I drew, if you PM me your email.
February 9, 201214 yr You can also contact Ryan at RAM Designs. He is a member here, and he has a web site too : google ram design to find the exac adress. He makes really good designs.
February 10, 201214 yr Author Has looked at the drawing.Thanks.Its me it seems that V=60 liters too small I thought 70 it is necessary. Power nearby 2000 watt. Edited February 10, 201214 yr by Nikita
February 10, 201214 yr Author You can also contact Ryan at RAM Designs. He is a member here, and he has a web site too : google ram design to find the exac adress. He makes really good designs.I don't understand. It is possible more in detail and more particularly.
February 10, 201214 yr You can also contact Ryan at RAM Designs. He is a member here, and he has a web site too : google ram design to find the exac adress. He makes really good designs.I don't understand. It is possible more in detail and more particularly.Click me http://www.ram-designs.com/contact.php
February 10, 201214 yr Has looked at the drawing.Thanks.Its me it seems that V=60 liters too small I thought 70 it is necessary. Power nearby 2000 watt.Yeah I designed it for rated power. Talk to the RAM, but I am sure it will cost you.
