Posted February 21, 201213 yr i was wondering whats the correct way to connect a audiocontrol dqxs & audiocontrol epicenter since i was told to put my epicenter before the dqxs and not after dqxs can some correct this for me please
February 21, 201213 yr Author There are wiring schematics on the Audiocontrol website.yes but nothing with a dqxs & epicenter
February 21, 201213 yr Admin Do you already have the Epicenter?yesThe Epicenter add's distortion to the signal. It was created for recordings, mostly on cassette tape, that lost much of the low end during playback. Now that it is no longer an issue with digital and CD's, the epicenter only overblows the low end frequencies and can throw the overall sound out of balance.
February 21, 201213 yr Author Do you already have the Epicenter?yesThe Epicenter add's distortion to the signal. It was created for recordings, mostly on cassette tape, that lost much of the low end during playback. Now that it is no longer an issue with digital and CD's, the epicenter only overblows the low end frequencies and can throw the overall sound out of balance.so how do you recommend me to connect it whats the right way to have it connected
February 21, 201213 yr Author Get rid of the epicenter. Denim gave you reasons why it is not needed.i thought about that but i like how it sounds with country music & classic rock and other types of music but RAP i dont like how the epicenter sounds with RAP
February 21, 201213 yr Admin If you like it, that is what matters really. Personally, I guess I would put it in line after the DQXS.
February 21, 201213 yr Author If you like it, that is what matters really. Personally, I guess I would put it in line after the DQXS.i was told to feed the epicenter with a full range signal
February 21, 201213 yr Author you may need to change the chip set it,you may need to change the chip set it, ??????? how
February 21, 201213 yr here is a bit of info on it.. you can google and find tons more... .it has even been discussed on this site.http://www.makeitlouder.com/epicenter.html
February 21, 201213 yr Author here is a bit of info on it.. you can google and find tons more... .it has even been discussed on this site.http://www.makeitlou.../epicenter.htmlwow i didn't know that thanks bro and which chip do i need my subs would be 2 fi sp4 18s D2
February 22, 201213 yr Author If you like it, that is what matters really. Personally, I guess I would put it in line after the DQXS.which of these chips do i need 18dB/Octave Crossover or PFM Frequency ModulesAvailable Frequencies in Hz15, 20, 25, 30, 35, 40, 45, 50, 60, 65, 70, 80, 90, 100, 120, 130,150, 170, 200, 270, 350, 500, 725, 950, 1500, 2000, 2600, 3000, 3500, 4000, 4500, 5500, 6000, and blank.labeled and certified24dB/Octave Crossover Frequency ModulesAvailable Frequencies in Hz50, 60, 70, 80, 90, 100, 120, 150, 170, 200, 250, 350, 450, 500, 750, 950,1500, 2500, 3500, 4500, and blank.labeled and certified Edited February 22, 201213 yr by CHRIS 323
