February 22, 201214 yr Ohm's law is invaluable.. Take the total wattage and divide it by your idle voltage. That will give you the amount of amps drawn to select a fuse. My calculation is roughly 60 amps. So yes, it's plenty.
February 22, 201214 yr That's good enough for a rough estimate. There's a LOT more to it than that, but he's right, you should be just fine with 750 watts on a 105A alternator. In my relatively short experience I've found that most stock electrical systems can handle up to about 1,000 watts without too much trouble. EVERY vehicle and situation is different though so you'll have to watch your voltage and see how it does. You should do a BIG 3 upgrade for good measure to help the stock backbone and be sure you have a good battery too. If your voltage drops badly, then you'll have to look at a solutions to the problem, if not then bump away happily.
February 22, 201214 yr Are you asking about a 105a alternator?If so, what else do you have hooked up? Keep in mind your vehicle can use the majority of the alternators ouput. If you use your amplifier at a low impedence more current will be required as well.
February 22, 201214 yr Edit: double post, seems to happen a lot lately Edited February 22, 201214 yr by edouble101
February 22, 201214 yr That's good enough for a rough estimate. There's a LOT more to it than that, but he's right, you should be just fine with 750 watts on a 105A alternator. In my relatively short experience I've found that most stock electrical systems can handle up to about 1,000 watts without too much trouble. EVERY vehicle and situation is different though so you'll have to watch your voltage and see how it does. You should do a BIG 3 upgrade for good measure to help the stock backbone and be sure you have a good battery too. If your voltage drops badly, then you'll have to look at a solutions to the problem, if not then bump away happily.I misunderstood the question a bit. He didn't specify alternator capability. I assumed he was trying to select a fuse size. Yes, there is more to it, but that was a short answer to his question.
February 22, 201214 yr That's good enough for a rough estimate. There's a LOT more to it than that, but he's right, you should be just fine with 750 watts on a 105A alternator. In my relatively short experience I've found that most stock electrical systems can handle up to about 1,000 watts without too much trouble. EVERY vehicle and situation is different though so you'll have to watch your voltage and see how it does. You should do a BIG 3 upgrade for good measure to help the stock backbone and be sure you have a good battery too. If your voltage drops badly, then you'll have to look at a solutions to the problem, if not then bump away happily.I misunderstood the question a bit. He didn't specify alternator capability. I assumed he was trying to select a fuse size. Yes, there is more to it, but that was a short answer to his question.Double post.. Again OOPS Edited February 22, 201214 yr by BrutalBasser
February 22, 201214 yr Author Only other upgrade is my alpine cde122 hu. ThanksSo with a multimeter is there a way to check for voktage drops when car running and stereo running?
February 22, 201214 yr Only other upgrade is my alpine cde122 hu. ThanksSo with a multimeter is there a way to check for voktage drops when car running and stereo running?Easily at idle. You should be ok. As long as your alternator and battery are in good condition.Do the "big 3".
February 22, 201214 yr Whats the big 3BatteryAlt& what? My battery is just about a year oldhttp://www.the12volt.com/installbay/forum_posts.asp~TID~73496~PN~1
February 22, 201214 yr Whats the big 3BatteryAlt& what? My battery is just about a year oldLots of info, google it. Some helpful youtube vids available too.
February 22, 201214 yr Author Thanks. I hope i dont have to do that. I suck at mechanics and i never had to work on this carSo at idle how would you check for voltage drops? Just place mm leads on battery terminals? Should be at 12v if its ok right?Oe will the amp draw some of the volts down?
February 22, 201214 yr The amp will draw it down on hard pulls such as a sustained bass note at full volume. You'll want to check it like that at the terminals of the amp for the most accurate idea of what's happening since the voltage drop will be worse at and on the amp than anywhere else in most cases.
February 22, 201214 yr Thanks. I hope i dont have to do that. I suck at mechanics and i never had to work on this carSo at idle how would you check for voltage drops? Just place mm leads on battery terminals? Should be at 12v if its ok right?Oe will the amp draw some of the volts down?Measure the voltage with the engine running, determine your idle voltage, then turn your stereo on and watch your meter for drops. Edited February 22, 201214 yr by BrutalBasser
February 22, 201214 yr Idle voltage should be +14v. Idle voltage is difficult to maintain that high with an aftermarket stereo on a stock alt. Doesnt really give you a good indicator of electrical system performance for your need.You should be able to have a buddy hold your engine rpm's above 1500 while you measure voltage at the amplifier. There are other ways to measure voltage but I dont think you are ready for that yet.
February 22, 201214 yr 90 amp alt can hold my 1500w amp just fine. I only get slight dimming if I am running it full tilt for 10 mins at idle. And that's just slight dimming. As long as you have a stong battery under the hood you're fine.AND the 90amp alt on my old taurus held 2250 watts total for about 3 mins before dimming. With a terrible duralast gold. Edited February 22, 201214 yr by djtomczak
