Posted February 25, 201214 yr Someone told me he doesnt trust setting the gain by a multimeter so he goes by um i believe the sub burning up then lowers it to a stable pointNow that doesnt sound safe... how did you do it?
February 25, 201214 yr By ear and experience. For you I'd get someone that knows what they are doing to help you set it. If you think you can do it with a dmm properly that would be a good option. Setting the gain by smell is a bad option.
February 25, 201214 yr Author Well i dont know anyone. Im going out tomorrow to buy my bolts and i guess i will pick up a dmmI know what it needs to be set at... i dont know how to go by ear yet
February 25, 201214 yr Someone told me he doesnt trust setting the gain by a multimeter so he goes by um i believe the sub burning up then lowers it to a stable pointNow that doesnt sound safe... how did you do it?HAHA you didn't understand what I said in the least. If that's what you got out of it I don't know what to do to help
February 25, 201214 yr Author Im just trying to understand this bro. This aint easy for a newbieDo i set amp crossovers after setting gain?
February 25, 201214 yr Set crossovers before gain, make sure bass boost and all the crap is turned off.
February 25, 201214 yr Set crossovers before gain, make sure bass boost and all the crap is turned off.Buy a good dmm not one for 15.00 dollars
February 25, 201214 yr there are alot of guides on how to set amplifier gain, some reading should help in your case, then ask questions after...
February 25, 201214 yr Author You assume to muchIve been non stop reading on everything. I wad up till 2am researching on this
February 25, 201214 yr You assume to muchIve been non stop reading on everything. I wad up till 2am researching on thisdid not assume anything, Just trying to get you started from them basic as you have not indicated anything of the sort previously and, an understanding the fundamentals is essential if you choose to do it by your self.was just trying to help !anyways good luck.
February 25, 201214 yr Author Gotta start somewhere. I mean i cant see how you cant do it if you dont have thatTo much gain you get clipping "indicated light on amp"To little - less power. So just gotta work around
February 25, 201214 yr cheap DMM's work fine for the occasional user. I have a cheapo (clamp/DMM) from harbor freight and its damn near spot on with my dads fluke and snap on. DD1 works great also, I know some people talk ish about it. But it really is spot on. Takes 5min lol.I love mine.
February 25, 201214 yr First time setting your amp setting, don't worry about max power. That should be the least of your worries. Since you admit to not know much then don't try to push your equipment the first time you turn it up, you're going to blow something.
February 25, 201214 yr First time setting your amp setting, don't worry about max power. That should be the least of your worries. Since you admit to not know much then don't try to push your equipment the first time you turn it up, you're going to blow something.Is the dmm method a good place to start?
February 25, 201214 yr First time setting your amp setting, don't worry about max power. That should be the least of your worries. Since you admit to not know much then don't try to push your equipment the first time you turn it up, you're going to blow something.Is the dmm method a good place to start?Refer to your thread about the matter.
February 25, 201214 yr you cant properly set gain by dmm. you need a oscope . or experianceAn o-scope isn't any more helpful than a DMM for gain setting.
February 25, 201214 yr cheap DMM's work fine for the occasional user. I have a cheapo (clamp/DMM) from harbor freight and its damn near spot on with my dads fluke and snap on. DD1 works great also, I know some people talk ish about it. But it really is spot on. Takes 5min lol.I love mine.I just like to buy a meter that can be calibrated.
February 25, 201214 yr Been setting gain for 3 years with a DMM.Haven't ran into a problem yet. Don't worry. You'll get a hang for things
February 25, 201214 yr you cant properly set gain by dmm. you need a oscope . or experianceYou can properly set gain any way you want. Oscope will do nothing aside from showing you the wave form. Doesn't mean the gain is set correctly or not. The best way is to trust your ears.
February 25, 201214 yr you cant properly set gain by dmm. you need a oscope . or experianceYou can properly set gain any way you want. Oscope will do nothing aside from showing you the wave form. Doesn't mean the gain is set correctly or not. The best way is to trust your ears.Well said Sir.
February 25, 201214 yr Been doing the gains on my stuff by DMM since day 1.Nothing has ever gone wrong.
