To view our products and tech support help sections, please visit our website at www.spllabusa.com
Carrying Cases-
We are currently out as we transition to a new style that's better for the customer. When they come in, we will post pics and specs in this thread and in a new thread.
USB Meter-
Designed to work with a computer
Only requires packaged USB cable
Software available for free
Accuracy- 120-179dB +/- 0.1db
Noise Floor - 90-100dB
Frequency Range - 10Hz - 120Hz - New for 2012
Real-time, Peak Hold, Averaging and more coming soon...
ADC Unit - 16bit
Processing Algorithm - FFT with smoothing
Inner Power Supply - USB port
Signal Type - periodic, sine or square
Software - Measurement Center 2
USB Pro Meter-
Dual pressure meters
Comes with USB cable, 2 Cat5 cables, datalink box
ADC Unit - 16bit
LCD Meter (fully portable, no pc required bass meter)-
Designed to work WITHOUT a computer
Comes with USB cable, Data link cable, 12v power adapter
Accuracy- 120-180dB +/- 0.1db
Noise Floor - 110-120dB
Frequency Range - 20Hz - 120Hz
Real-time, Peak Hold, Averaging and Flashable onboard ROM
Processor - Atmel 16MHz
ADC unit - 14bit
Main Block Display - Two Line display with backlight
Inner Power Supply - 2 AA Batteries (not included)
Outer Power Supply - 12v car adapter
(innerouter only need one of the two to operate)
Signal type - periodic, sine or square
Sockets - Sensor socket (3.5mm jack), 12v car adapter and USB port
Wireless Bluetooth Meter (wireless bass meter)-
Designed to work with a computer or Android device(tablet or cell phone).
Accuracy- 130-180dB +/- 0.1db
Noise Floor - 90-120dB
ADC unit - 14bit
Link Protocol - Bluetooth 2.0 + EDR Class 1
Inner Power Supply - Li-Ion 800mAh
Outer Power Supply - USB port for recharging
Battery Life - Up to 3hrs in data transmission mode
Software for PC - Measurement Center 2
Software for Android Cell phoneTablet - SPL-Lab Android
Signal Transmission distance - up to 100 Meters (unobstructed)
USB Noise Meter (RTA low budget)-
Amplitude- 80-140db
Frequency Range - 20Hz - 15000Hz
ADC unit - 16bit
Signal type - Broadband noise
RTA PRO Meter (Professional, Extreme Accuracy RTA) -
RTA full range meter
Accuracy- 90-130dB +/- 0.1db
Noise Floor - 60-70dB
Frequency Range - 10Hz - 20000Hz - New for 2012
Real-time, Peak Hold and more coming soon...
ADC Unit - 16bit
SQL Meter (Highly Advanced Broadband RTA Meter) -
For more information on this meter, please go to this thread-
SQL Meter Info Thread
Amplitude - 120-165dB
Frequency Range - 20 Hz - 20000 Hz
LOUD Games format usage ONLY for proper accuracy
ADC unit - 16bit
Calibrations - Custom, LOUD Games format
How does SQL Meter measure pressure?
This is what separates the past from the future of measuring pressure.
The SQL Meter uses a special algorithm used to bring the oldschool competition back! No more burp only, no more tuning your system JUST for a specific range, etc....
The SQL Algorithm is the TRUE method of distinguishing who has the loudest overall stereo system out there.
People with 170db+ extreme vehicles will now be EQUALLY competitive with those who run an amateur style aftermarket setup that may have less than $1,000 invested.
How is this possible? This is how it works-
User will be metered for 30 seconds. In these 30 seconds, something very interesting is happening...
For EVERY SECOND the meter is measuring of the 30 seconds, it will be finding 1 peak PER range using the following ranges-
20-26 Hz
26-33 Hz
33-40 Hz
40-53 Hz
53-66 Hz
66-80 Hz
80-160 Hz
160-320 Hz
320-640 Hz
640-1280 Hz
1280-2560 Hz
2560-5120 Hz
5120-10240 Hz
10240-20000 Hz
Good Luck! :)
Active measurable SPL ranges during measuring- 120-165dB.
Capable averaged scores at end of 30 second run- 0dB - 165dB.
PS - Nobody in the history of the SQL Meter that we have ever known has been able to average over 150dB. And as a matter of fact, not even 140dB.
Remember, the meter locates peaks in ALL ranges. If your stereo cannot play very well in ANY particular range, your score will suffer very bad and your choice of music is also a major part in doing well also.
Edited by shizzzon
Let me make a thread for that.
ALL IMAGES ARE NOW UPDATED!
pics look good sean :)
  • 2 months later...
How can I order just a case for the hand held?
