Posted March 19, 201214 yr Ive had to scrap my original idea of using a single 8 due to the port length / space limitation for where I wanted it. Ive decided to use the pair i have and not worry about the space required. Im guessing eclosure volume would be double the single so 1.2-1.5 cuft, what should my port size and length be? this will be for every day usethanks
March 19, 201214 yr Author After a little reading, i think slot port is the way ill be going Edited March 19, 201214 yr by Tarpon87
March 19, 201214 yr Now we need some max external dimensions you are willing to sacrifice for an enclosure. This at a minimum would need to be greater than your required air space, plus the displacement of your slot port, and your subs. What vehicle is it going in will also help.
