April 30, 201214 yr Author um 96.4 dbs isn't even loud.I know THat's the second meter.. I don't hve lol
May 2, 201213 yr Author Finally got my drag bags in... took me about 2 hours total for both sides install was pretty easy but getting started was a PITA!pics incoming
May 2, 201213 yr Author ride is about 15 times better, no more huge bumps but does feel a bit more springy.
May 3, 201213 yr Author You said you didn't want blocks. I would have gave you mine. 24 holes.totally forgot you had those.. its cool man
May 7, 201213 yr Author Installed my Line driver today..Did not realize how small and heavy it was.. looks great IMOI'm getting a little too loud Spliced the wires for some connectors to facillitate the power and ground for the line driverPackaged it all up in my glove box, where I can tune it if need be.
May 8, 201213 yr Author On the dash finally got my 152.2 back did it at 37hzLittle bit of progression....8 db nearly from the switch from PowerBass to SundownCompletely sealed up in the kick.. not a bad score!
May 8, 201213 yr Author I think next time I get Im going to run a 149.9 bass race class... I can get damn close no problem.
May 12, 201213 yr Author Around 250 ft of 8ga and 100ft of 1/0...The Audio Technix wire is ok. That's all I can really say.Getting my GF to do some work Her cutting some of my new 8gaOne side wired upFinal postioningAll I have for now, only one sub is wired up, I will do the other side when it stops raining. Edited May 12, 201213 yr by Julian
May 12, 201213 yr Author stock alt is looking burned up only getting 13v out of it running... lol good thing I ordered my new one
May 12, 201213 yr Author Run from my rear battery to my volt meterup into the dashTest fitGot my RCA's in and everything wired up getting loud!
