September 8, 201213 yr Author nope could not work this weekend, will work next week should be done before the 15th
September 10, 201213 yr Build looks good, as others said I would change your Lugs and get some cheap wire hammer crimpers and a sledge hammer, even if you had to shed alittle wire to get them in it will not have any current affect at all. Works like a champ. Also be careful on having the mids crossed so low. They even say from 80hz+ on the specs. A good loud sub 60 note may just smoke one. I have mine crossed at 80 but thats just meGreat build and look forward to seeing your progress. Edited September 10, 201213 yr by swift
September 10, 201213 yr Author Build looks good, as others said I would change your Lugs and get some cheap wire hammer crimpers and a sledge hammer, even if you had to shed alittle wire to get them in it will not have any current affect at all. Works like a champ. Also be careful on having the mids crossed so low. They even say from 80hz+ on the specs. A good loud sub 60 note may just smoke one. I have mine crossed at 80 but thats just meGreat build and look forward to seeing your progress.No subs, so I run em low I'm going to cross them at 100-150hz when I have subs
September 10, 201213 yr Build looks good, as others said I would change your Lugs and get some cheap wire hammer crimpers and a sledge hammer, even if you had to shed alittle wire to get them in it will not have any current affect at all. Works like a champ. Also be careful on having the mids crossed so low. They even say from 80hz+ on the specs. A good loud sub 60 note may just smoke one. I have mine crossed at 80 but thats just meGreat build and look forward to seeing your progress.No subs, so I run em low I'm going to cross them at 100-150hz when I have subsThe doors look amazing BTW
September 10, 201213 yr a little O/t but bought ,myself an early bday presentnew craftsman mechanics tool set with 360+ peices and a new 9 drawer boxThat's a very nice early bday present.
September 10, 201213 yr Author My friend did a little progress for me,the port will but not be up and down, It will look similar to our vans wall, we will get around 350 Sq in of port and we're aiming for a tuning of 35-37hz.
September 11, 201213 yr Author After a few minutes of what I call "Math" I estimated the overall cubic feet of my wall and came up with around 16.3 cubic feet, which should work nicely. It's a few more cubes than last.
September 14, 201213 yr My friend did a little progress for me,Just look at all those sweet asses. Exactly what I was thinking. Great shot!
September 16, 201213 yr That is going to look awesome!Please clean that sub, I hate to see dirty subs.
September 17, 201213 yr Blasphemy! That sub deserves better! Ill treat it nicely for ya Lookin GREAT btw! Edited September 17, 201213 yr by AXEHAMMER
September 30, 201212 yr Author The general Idea, the batteries are supported by a 2x4 base.The jumpers from the left pair to the right pair is wired up with some 2/0All done...I will be recarpeting the floor, the base is supported by 2x4's around the outside, the floor is not touching the batteries. Edited September 30, 201212 yr by Julian
