  • Replies 467
  • Views 46.9k
DAMN that looks sexy!
Once u get the new amp I need to come hear it!!
Looks badass bro
  • 4 weeks later...
Update?
  • 2 weeks later...
Hell yeah! That's a lot of power!
wow, crazy son
  • Admin
That's a lot of power for sure!!!!!!!!
  • 3 weeks later...
The alt bar is 1/2" thick by around 6" long, It was made by ProjectDB and it is in no danger of arcing on anything.. it has good clearance all around, but for an extra layer of security I put several layers on the bottom/sides.
WELCOME back man! What happened to your batts? Are they under warranty?
Okay, Finally got the battery situation figured out. The people at Sears could NOT find my invoice, they said they couldn't find anything (come to learn 99% likely they didn't want to warranty them out because it means money out of their pockets), so I had my friend who works at a different local sears store.. Within 5 minutes he had it pulled up and faxed over, with invoice in hand they STILL "couldn't" find the original invoice even with the same invoice numbers.. After about 5 minutes of bitching at them they finally pulled it up.. THEN they tried to nit pit about how on the computer the product number is xxxxx31 and on the receipt it said xxxxx31m. After a few more minutes of bitching them out they finally agreed to warranty them out.
What I'm "assuming" what happened; is one of them had a bad cell and it drained the shit out of them to the point where the went bad. They sat 2 months uncharged in very cold temps in my garage
Initial test fit,
Seems like they were almost made to fit, they fit tightly side to side, luckily the C&D's were less than .25 wider than the diehards.
put the larger C&D's on the outside to distribute the weight of the larger batts.
Used a strip of 12 ga angle iron (I don't know the exact name) to hold them from moving backwards.. Yes those are wing nuts, I ran out of washers and wanted to get it all in, lol.
  • Admin
Looking good. Nice to see that trusty ZED amp tucked away in there. :)
