March 28, 201214 yr Admin The output is violent, pressure that truck can build is more then you expect. The install may not be for everyone, but you have to respect the results of this install.
March 28, 201214 yr Author All vids an numbers were on two 3ks an 7 batts didn't have my alt going it did a 153.5 at 35hz at the end of 30sec sealed an that was at the end of the second day of demoing the shit out of it, i will update with real numbers when i get a few things worked out. Edited March 28, 201214 yr by 89jimmy22
March 28, 201214 yr All vids an numbers were on two 3ks an 7 batts didn't have my alt going it did a 153.5 at 35hz at the end of 30sec sealed an that was at the end of the second day of demoing the shit out of it, i will update with real numbers when i get a few things worked out.very nice
March 29, 201214 yr This blazer pushes more air than any other vehicle I have demoed. You can feel air from over 6 feet away.
