Posted April 10, 201214 yr so my buddy is really cheap, hes not into heavy bass but does like a little bit, but like i said realy a big cheap sk8,hes been looking on amazon at amps and subs/enclosures, hes been looking at Dual-Pyle-Pyramid-Boss-Lanzar-Planetaudio-Mtx-etc...(huno cheap stuff),i told him to hold off give me a couple of days see what i can come up with,he wants 12's but i thank he might go for some 10's, remember hes a cheap $#@, hes looking to spend around 200-250, again hes cheapif you have any suggestions (besides quiting beeing cheap) or have something youd part with, fell free to text meSamuel970-599-4197or himJoe970-388-5652(hell just ask me what i thank so itll come back to me anyways)i have wiring and a HU for him and some xplod's for his doors,thanksSamuel
April 10, 201214 yr He wants 2 subs, an amp, a box, wiring for everything...for $250 ? Good luck !!!Unless he buys used, I can't see that happens easily.Classifieds, Craiglists,...etcSee what you can find. Look for a single sub, it will be cheaper than 2 !
April 10, 201214 yr $300 systems sound like $300 systems. You're not going to find anything good for that much. If you do, it would be a single sub that wasn't very loud. Maybe a couple of tens or something...
April 10, 201214 yr If you guys are willing to and can build the enclosure yourselves then an SSA DCON and a decent little amp to run it would fit the bill perfectly. I think you could get the sub, an amp, wiring and the materials needed to build the enclosure for about $250 to $300.
April 10, 201214 yr honestly theres not much a cheap person can do ill suggest save more money and get something good
April 10, 201214 yr Such as this:15" SSA DCON D4 $140MB Quart FX1.400 $80KNU KCA 4AWG amp kit $27Box building materials roughly $60Total = $307Given the enclosure is designed and built correctly it would be a fine first setup.He could save $15 going with a 12 instead of the 15 or $25 with the 10. All things being equal the 15 will be louder tho so that's why I listed it.
April 10, 201214 yr Author thanks everyonei sat down with him about hour ago and he saidfind me an amp for 150.00and ill get that this checkfind me subs/box for 250.00and ill get them next check(i gave him door Speakers-HU-Wiring already)weve made progress
April 10, 201214 yr Get two DCON twelves or a fifteen and a cheap audiopipe amp, and build your own box.
April 10, 201214 yr I have a 350rms amp at 4 ohms I could sell for 50+ shipping. Two channel amp so 4 ohms bridged. Soundstream PCX2.350
April 10, 201214 yr Author hes ordering the 15" dgon when he getts home from work,so i need help with a box design pleasemax space avalibale is17H x 41W x 26Dand is the box single double tripled, how thick is the material, facing what direction(vent/woofer)please note that the only tools i have are, circle saw, jig saw, drill, cocking gun,Tape measure, chock line, triangle(rest of my tools are in storage)thanks everybodySamuelo and hes getting the audiopipe ap-10001d
April 11, 201214 yr Author There are some free designs in the store that will work for you.were do i find the free design
April 11, 201214 yr http://www.soundsolutionsaudio.com/index.php/product-information/dcon.htmlClick the tab that says predesigned enclosures
April 11, 201214 yr hes ordering the 15" dgon when he getts home from work,o and hes getting the audiopipe ap-10001dGood choices for the budget! What VC config do you plan on ordering?
April 11, 201214 yr Author http://www.soundsolu...ation/dcon.htmlClick the tab that says predesigned enclosuresthanks appreciated
April 11, 201214 yr Author hes ordering the 15" dgon when he getts home from work,o and hes getting the audiopipe ap-10001dGood choices for the budget! What VC config do you plan on ordering?i told him to order it as a D4 so the one can be loaded @2ohm(around 300-600 rms not sure what the actual output is) and hell still have the opption to get a 2nd D4 and the amp is 1ohm stable Edited April 11, 201214 yr by SamuelHermon
