Posted April 23, 201213 yr Look what I found on eBay. http://www.ebay.com/itm/Rockford-Fosgate-T15KW-Power-Cube-15-000-RMS-30-000-Watts-/120897338180?pt=Car_Amplifiers&hash=item1c260afb44
April 23, 201213 yr DAMN I have heard of those, although never seen one! and for 6k$ that is a steal! although keep in mind the size! 37x22x10 and 180lbbut he will hand deliver! Edited April 23, 201213 yr by CrazyKenKid
April 23, 201213 yr Look what I found on eBay.http://www.ebay.com/...=item1c260afb44how many batteries do you need to power this beast ? i wish i had $6k
April 23, 201213 yr Author Battery I don't know, I know Meade916, Steve Meade on you tube has 8 d3100's powering 2(two) t15k's and that is ferocious. 4 alts from mechman, the 370 amp versions, 8 50 foot rolls of 0 gauge just for the alts and amp. Wtf. A warhorse from kicker would seem more logical
April 23, 201213 yr Author $25k to be exact. And only 18 ever made. Steve Meade has 4 so that leaves 12 left in the world!
April 23, 201213 yr It just seems like something to buy to say " I got 1" like Steve said $6k for 15,000watts is not the logical choice.
April 23, 201213 yr What makes this amp unique is that is actually OVER 100% efficient, which means you dont have to have as much for electrical than a standard 15k amp, and thats due to the fact that it has 180 caps. So its pretty much its own power house, and thats why you only see 1 set of 1/0 inputs.
April 23, 201213 yr What makes this amp unique is that is actually OVER 100% efficient, which means you dont have to have as much for electrical than a standard 15k amp, and thats due to the fact that it has 180 caps. So its pretty much its own power house, and thats why you only see 1 set of 1/0 inputs.Are you sure about that? Lets think about this here, where does all of this energy come from? The energy that these 180 caps need. Tell me how a capacitor works and operates.
April 23, 201213 yr Author I don't buy the 100% either. Power in = power out. You have to charge the cap, then it discharges. But along the way ther has to be some power loss and distortion somewhere due to heat, thermal dynamics, wire resistance, circuit board resistance? How can it be over 100% efficient?
April 23, 201213 yr From the designer himself.Yes it is true the idea came from a defibrillator. It seemed silly to me that all these guys in the db drag lanes need to have 1/2 of their vehicle full of batteries and alternators to maintain a decent B+ voltage for a few seconds. That and the fact that the amount of total energy all those batteries contain is huge and they are only using a fraction of it during their burp. It is like taking a NASCAR car to a drag race. A vehicle that is designed to go 200mph for hours on end probably isn't the best design for a 1/4 mile burst.So when you look at the way a defibrillator is used its like burping an amp. Defibrillators don't have massive power cords that need mega amps at 220V, in fact some of them are portable and run off a very small battery. Why, because they don't need to shock someone for hours at a time, just a quick burst. They just draw a small amount of power continuously during 'charge up' and once all the energy they need is accumulated they release it all at once. With the operation of the defibrillator in mind, I tried to apply it to car audio. I set off to build a prototype which was based on (2) T1500.2 output sections, I had to liquid cool the MOSFETs because even the FETs in the T1500.2's were not big enough to handle the kind of power I wanted. By keeping them very cold they could be pushed beyond their limits. (This may be the radiator ect... part of the story that someone posted). Then I needed a way to store a bunch of energy, electrolytic caps and some of the carbon based caps that are commonly used in car audio were not even close to being capable of storing the amount of energy I needed, so I used 12 small motorcycle batteries in series to get 140+ Volts. Then I built a power supply that would convert 12VDC to 140VDC to 'charge' these batteries. I got this contraption all put together the night before the Annual Rockford Fosgate Employee Sound-Off. I didn't really how much power it would make exactly, but to try to shorten this long story it ended up putting out 15,030 Watts RMS! This is how 15k Watts became the goal for a 'real' amp. The first step towards making it a 'real' amplifier was I had to eliminate the array of batteries. I began searching high and low for something that would do it. I found a company that makes capacitors for hybrid cars and large wind turbines. These worked perfectly. The caps I ended up using are 400 Farads, and there are 180 of these in the T15kW. Then I needed an intelligent power supply that could monitor these caps and add energy to them as needed, and it had to be fast, really fast if this amp was going to play music and not just a burst. So during music these caps are charging, discharging, charging, discharging. The power supply in the T15kW can charge the caps 35,000 times per second. Of course many other things had to happen like finding MOSFETs that could handle it, a way to keep it cool without antifreeze and car radiators ect. The final product met all the goals and then some. The main idea is that with this technology the amplifier can put out more power during transients or bursts than the car it's connected to could supply.
April 24, 201213 yr What makes this amp unique is that is actually OVER 100% efficient, which means you dont have to have as much for electrical than a standard 15k amp, and thats due to the fact that it has 180 caps. So its pretty much its own power house, and thats why you only see 1 set of 1/0 inputs.It's not over 100% efficient. I don't care what marketing BS the designer wishes to spread.All it does is trade-off lower peak current draw for higher continuous current draw. It's still drawing the power from the electrical system to supply the capacitor bank, it's not a generator that creates it's own power. Only difference between this and a standard amplifier is that on large musical peaks it utilizes the capacitor bank to decrease the peak current draw from the electrical system, however the downside is that the current draw is going to be higher during non-musical peaks because it then has to recharge the capacitors. So yes, you will still need a very hefty electrical system since the continuous current draw from the electrical system will be extremely high compared to a standard amplifier.The reason it only has 1 set of 1/0 gauge inputs is because it's peak current draw is 350A. But again, that's peak current draw and says nothing about the increased continuous current consumption from the electrical system. When a "normal" amp nearly stops drawing current because the music stopped, this thing is going to continue drawing large amounts of current to recharge the caps. Again, it's a giant capacitor, not a generator. It doesn't create power, it stores it. It needs to get that power from somewhere, which is the electrical system.Also calling it a 15kw "RMS" amplifier is a bit of a mistruth. Based on the capacitors, it can only supply 15kw for 16 seconds before the capacitor bank depletes. It's actually a 4kw RMS amplifier with 15kw "burst" power, not a true 15kw continuous power amplifier.
April 24, 201213 yr $25k for 4k amp. Meh, ill put a down payment on a second houseAs a college kid...I heard that shit...Get a nice car or something...
April 24, 201213 yr $6k seems like a shit ton to pay for 15000w.X2especially if it only does 4k rms like there saying ^^^
April 24, 201213 yr What makes this amp unique is that is actually OVER 100% efficient, which means you dont have to have as much for electrical than a standard 15k amp, and thats due to the fact that it has 180 caps. So its pretty much its own power house, and thats why you only see 1 set of 1/0 inputs.It's not over 100% efficient. I don't care what marketing BS the designer wishes to spread.All it does is trade-off lower peak current draw for higher continuous current draw. It's still drawing the power from the electrical system to supply the capacitor bank, it's not a generator that creates it's own power. Only difference between this and a standard amplifier is that on large musical peaks it utilizes the capacitor bank to decrease the peak current draw from the electrical system, however the downside is that the current draw is going to be higher during non-musical peaks because it then has to recharge the capacitors. So yes, you will still need a very hefty electrical system since the continuous current draw from the electrical system will be extremely high compared to a standard amplifier.The reason it only has 1 set of 1/0 gauge inputs is because it's peak current draw is 350A. But again, that's peak current draw and says nothing about the increased continuous current consumption from the electrical system. When a "normal" amp nearly stops drawing current because the music stopped, this thing is going to continue drawing large amounts of current to recharge the caps. Again, it's a giant capacitor, not a generator. It doesn't create power, it stores it. It needs to get that power from somewhere, which is the electrical system.Also calling it a 15kw "RMS" amplifier is a bit of a mistruth. Based on the capacitors, it can only supply 15kw for 16 seconds before the capacitor bank depletes. It's actually a 4kw RMS amplifier with 15kw "burst" power, not a true 15kw continuous power amplifier.Thank you for explaining that brad, I hope Bamf101 will be able to understand.
May 1, 201213 yr Ive heard one of these amps. Running on 3 batteries on a single charging line if i remember correctly. It is expensive but i was impressed by how long it played music on the power supply it was on. It was a wall with a total of around 40 P1 12's.
