Posted March 7, 200620 yr I want to fit better quality tubes to a TU-600, do I need to re-set the bias/plate voltages or are the pre-amp tubes auto-biasing? if so where to I tweek the levels and where to I measure. thanks.
March 9, 200620 yr Author Anyone, surely someone must know if I can just swap the tubes and go or do I need to tweek and voltages?
March 14, 200620 yr Author Still no response I changed the tubes anyway. Its now running a pair of JJ Tesla ECC83s tubes and sounding much the better for it tonality and staging are a definitel improvement of the Sovtek 12AX7LPs fitted as standard.I'd still be interested to know if I can set the plate voltage / bias by the variable resistors on the board for this amp.
March 14, 200620 yr Admin Still no response I changed the tubes anyway. Its now running a pair of JJ Tesla ECC83s tubes and sounding much the better for it tonality and staging are a definitel improvement of the Sovtek 12AX7LPs fitted as standard.I'd still be interested to know if I can set the plate voltage / bias by the variable resistors on the board for this amp.PM jimJ on here, he is our resident tube expert
March 17, 200619 yr Still no response I changed the tubes anyway. Its now running a pair of JJ Tesla ECC83s tubes and sounding much the better for it tonality and staging are a definitel improvement of the Sovtek 12AX7LPs fitted as standard.I'd still be interested to know if I can set the plate voltage / bias by the variable resistors on the board for this amp.<{POST_SNAPBACK}>Will the JJ's filaments take the beating a vehicle driven on the road will recieve? The Sovteks will, and why they are used AFAIK. If not for daily driving and the abuse a vehicle takes, ANY, within reason, would suffice. IMO.Good luck.
March 17, 200619 yr ^^^ good point... cuz some home tubes arent meant to be jumbled around and such in a home environment?
March 17, 200619 yr Exactly.....paper thin filaments. (Also why ppl say they will break in a car i suspect.....as they know how fragile the HT's sometimes are.)
April 27, 200619 yr Author Well, they have been in for over a month now and still sounding great. they seem up to the job.
