so what would be the best way to run rca for 6 amps?
HU has 3 rca outputs front rear sub,
and if i understand corectly i can only do 1 amp in master and 1 in slave, so this would b ring me down to 3 for my sub amps what would be the next route?
Y adapters but not sure.
Usually, you use a combination of the rca pass throught on the amps (if available) and rca Y-adapeters
Are all 6 for your subs?
yes
6 15s-6 amps,
also
1 amp off of front for tweets and 1 amp off rear for mids,
total of 8 amps all together
yes
6 15s-6 amps,
also
Why a amp for each sub?
yes
6 15s-6 amps,
also
if i do an amp on each sub i can run at 2ohm load for starters and if i decide to down the road i can add a 2nd woofer on each amp
yes
6 15s-6 amps,
also
Ok
I would also consider a line driver as well for clean signal to so many amps.
What is a 15s-6? If it is a normal amplifier you can just use the RCA outputs. If you are not strapping the amps you are never running into a master/slave situation. You are simply passing the signal from amp to amp. It is only a through however so the signal might be reduced for 6 amps, so I would also recommend a line driver.
lol, I misread that. six 15s, six amps. Yeah what I said above.
