Posted May 4, 201214 yr Anyone be able to give me an idea of what this enclosure may be tuned to??I have a picture and a sketch with the measurements I took. The bottom right drawing is the port. It is shaped like an L, and above that I was trying to show that it is 16" in height.Any help would be great. Just trying to get a rough idea of what this enclosure is all about. It a "Turbo Vent" enclosure, could not find anything on the internet about them.
May 4, 201214 yr Impedance is highest at enclosure tuning. Therefore you could play a set of test tones, and measure the voltage at the amplifier's speaker terminals for each frequency with a dmm. Where ever the voltage is lowest, impedance is highest, and that's your enclosure tuning frequency.*The speaker will not be disconnected for testing.*There is no reason to play it loud for testing, I would do it at relatively low volume.If you don't have any test tones, say so, and I can provide a link.See below post. Edited May 5, 201214 yr by stefanhinote
May 4, 201214 yr Impedance is highest at enclosure tuning. Therefore you could play a set of test tones, and measure the voltage at the amplifier's speaker terminals for each frequency with a dmm. Where ever the voltage is lowest, impedance is highest, and that's your enclosure tuning frequency.*The speaker will not be disconnected for testing.*There is no reason to play it loud for testing, I would do it at relatively low volume.If you don't have any test tones, say so, and I can provide a link.Impedance is not highest at tuning. There are two peaks one above and one below tuning. The impedance graph would look something like this (Blue Line) for a ported enclosure, this one is tuned to about 31hz.OP, I have that enclosure figured at about 0.94ft^3 @ 44hz after port and driver displacement.
May 5, 201214 yr Author Stefanhinote, my measurements are internal measurements, (inside the box, the port walls act as the internal walls. I calculated about 2.12 ct foot for the enclosure, and port volume of .64 cu footAm I doing something wrong??So not including the woofer (not sure how much volume it takes up) I'm coming up with ~38hz tuning. There is also about 2lbs of poly fill in it.I'm not sure what the woofer displacement is, but
