Posted June 7, 201214 yr Why is it bad to have the height to width ratio larger than 1:8? I made a box that is too small.... and thats the only i really can make my box tund low enough... i fucked up and now im out 2 sheets of mdf and a lot of time and effort... damn..
June 7, 201214 yr "The ratio of W to h should not be any more than 9 to 1 to prevent tuning shifts introduced by excessive friction between the rapidly moving air and the port's surface. It should be noted that this is not a hard-and-fast rule, merely a rule of thumb to help you prevent a mis-tuning. In short, keep the port as square as aesthetically and physically possible."
June 7, 201214 yr I have made them as much as 12:1 and they still worked (and measured) correctly. You will be OK.
June 8, 201214 yr I have made them as much as 12:1 and they still worked (and measured) correctly. You will be OK.I'm about to make one almost to that ratio as well.I wouldn't worry about it. Just don't undersize it as well.
