Posted July 13, 201213 yr Hey guysI remember years back, when we wanted to build a "premium" subwoofer enclosure we would use birch plywood rather than particale board. Back in the late 1980s and early 1990s we mostly used particle board, not MDF, at least not at the shops I worked at. I don't know if it was because MDF wasn't widely available, or if it was more expensive, or if we just didn't know about it.So, my question is: What are your thoughts on using birch plywood for a subwooder enclosure? How do you think the enclosure would handle flex and can you comment about its tonal qualities?What brought this question to my mind is that MDF really is not a great material for holding fasteners (screws). If you swap your woofer out a few times the screw holes are more or less shot.I was think of using T-nuts or some other threaded insert, and use machine screws to mount the subwoofer. That way the woofer could be removed would damaging the enclosure.Care to brainstorm?Thanksjonblack
July 13, 201213 yr I've always used MDF until this last build and used 1" birch. I reinforced with 3/4" all thread rod. I like the sound of MDF better. Also, I recommend EZ-Loc threaded inserts. Place them on the underneath side of the wood and use machine screws with socket heads and I've never had another problem. Which is good because I use aeroports and always changing out to tweak the tuning.
July 13, 201213 yr I've read a couple of posts on birch vs. mdf and the big pros of the birch is weight savings, of course mdf is cheaper. You're spot on about the lack of longevity of the mdf and screwing and unscrewing but they make a great number of fasteners like you mentioned. Madisound and Parts Express should have everything you could ever want in the fastener department.
July 13, 201213 yr epends on the quality of the ply. Cheap ply is worse than mdf, good baltic birch ply (~$75/sheet) is better.I like the sound of MDF better.I'll assume by sound you mean you'd rather use it as acoustically you sure as shit aren't going to hear a difference.
July 13, 201213 yr Yes i mean acoustically. I paid $73 bucks a sheet for baltic. It is not as forgiving to work with as MDF either. But it is way lighter which is what I needed going from 1 x 15 to 2 x15s with extra amp and batteries. I'm also using spun metal flares on 10" aeros which seem to add a bit more noise than just having the PVC flared themselves. Both have pros and cons.
July 13, 201213 yr epends on the quality of the ply. Cheap ply is worse than mdf, good baltic birch ply (~$75/sheet) is better.I like the sound of MDF better.I'll assume by sound you mean you'd rather use it as acoustically you sure as shit aren't going to hear a difference.European Beech Ply is very strong and ridiculously expensive. The guy at the wood shop recommended it over Birch for strength.
July 14, 201213 yr Baltepends on the quality of the ply. Cheap ply is worse than mdf, good baltic birch ply (~$75/sheet) is better.I like the sound of MDF better.I'll assume by sound you mean you'd rather use it as acoustically you sure as shit aren't going to hear a difference.European Beech Ply is very strong and ridiculously expensive. The guy at the wood shop recommended it over Birch for strength.Called Baltic Birch here. Love it. In fact cut some tonight
July 22, 201213 yr Author Seems like I remember birch plywood enclosures having a different sound. Of course that was years ago and I may have been just imagining things. I wouldn't mind doing a comparison test just to see if I am remembering things right. Compare MDF or birch to a concrete speaker enclosure and I imagine one could tell the difference.Another thing we did that we thought made boxes sound better was paint the inside of the box. Any old paint would do. Years later I told a friend about that "concept" and he thought I was crazy. He had worked at higher end shops than I had and built many nice enclosures. The next enclosure he built he painted the inside. He said the box sounded awesome and was convinced that the paint made a difference. Of course, no blind test so at that point everthing is subjective. Lots of beer was drank in those days, though, so it may have had something to do with our perception.Anybody else heard of painting the inside of the box to improve the sound?jonblack
July 23, 201213 yr Painting it wouldn't be any different than fiberglass resin. It's going to act as a sealant and possibly make enclosure walls a little "smoother" for air flow transfer. MIGHT be measurable on a microphone but I seriously doubt the difference would be significant enough to be audible, unless the enclosure was poorly sealed to start with.
July 23, 201213 yr In a reasonably well built enclosure there will be no audible difference between mdf or ply.
March 6, 201411 yr Years back a team and I built 4 identical enclosures 2 where birch and 2 where mdf. 1 of each kind had fiberglass resin rolled on with a smooth foam brush roller on the inside. For testing we used the same drivers and power in the same car in the same location inside the vehicle taped off. Power was the same clamped (va) power. Both the plain unresin enclosures had the exact same score. The resined enclosures where indecisive same score or .1db loud
March 6, 201411 yr ohh and birch is much easier to work with and less mess (saw dust) and its just as strong or if not stronger then mdf
March 6, 201411 yr Does plexiglass or lexan color the sound at all, if you were to do an all plexi/lexan enclosure? Fuck the price tag, but just curious if it's a simple as make the box solid and sealed and you're good to go.
March 6, 201411 yr Not if you use 1" thick material and the box isn't too big... Price and assembly becomes prohibitive, though...
March 6, 201411 yr ohh and birch is much easier to work with and less mess (saw dust) and its just as strong or if not stronger then mdfDepends on which grade birch plywood!
March 6, 201411 yr Phenolic birch works well, plus it looks great. It can get expensive, though. Appleply Maple is another alternative to baltic birch. In all honesty, you're not going to notice much difference between any types of wood as long as you're not using particle board or cheap plywood with a lot of voids. The weight differences are huge, though.
March 7, 201411 yr Phenolic birch works well, plus it looks great. It can get expensive, though.Appleply Maple is another alternative to baltic birch.In all honesty, you're not going to notice much difference between any types of wood as long as you're not using particle board or cheap plywood with a lot of voids. The weight differences are huge, though.Curious about the weight differences.. Like full sheet (4x8)...
March 7, 201411 yr I used the Home Depot 5 ply birch and I love it. It seems to be very stong and I love the weight difference from mdf. It's extremely light compared to mdf. And it's only $10 more
March 7, 201411 yr I used the Home Depot 5 ply birch and I love it. It seems to be very stong and I love the weight difference from mdf. It's extremely light compared to mdf. And it's only $10 moreYea iv had a lot of successful builds using the birch they have at home depot and lowes. Could be a little better quality but iv never had problems with it and it seems a good amount lighter than mdf
March 7, 201411 yr Phenolic birch works well, plus it looks great. It can get expensive, though.Appleply Maple is another alternative to baltic birch.In all honesty, you're not going to notice much difference between any types of wood as long as you're not using particle board or cheap plywood with a lot of voids. The weight differences are huge, though.Curious about the weight differences.. Like full sheet (4x8)... Depends on the manufacturer.. A 4'x8' sheet of MDF (3/4") is around 90 lbs and cheap "birch plywood" will weigh around 60 lbs with a good amount of variance. Some manufacturers may have MDF that weighs, for example, 80 lbs per sheet and others may have MDF that weighs 100 lbs per sheet. Cheap birch ply often has a core made from cheaper wood and has a birch veneer on it. EDIT: Baltic birch According to one manufacturer's specs, a 4'x8' sheet of baltic birch that is 3/4" thick weighs 95lbs. I didn't realize it weighed about the same as MDF. We learn something new every day. Edited March 7, 201411 yr by Tenacious
March 7, 201411 yr In all honesty, MDF is probably the best material there is for building subwoofer enclosures. It self demapens well and is fairly strong.
November 10, 20205 yr On 7/13/2012 at 12:43 PM, jonblack said: Hey guys I remember years back, when we wanted to build a "premium" subwoofer enclosure we would use birch plywood rather than particale board. Back in the late 1980s and early 1990s we mostly used particle board, not MDF, at least not at the shops I worked at. I don't know if it was because MDF wasn't widely available, or if it was more expensive, or if we just didn't know about it. So, my question is: What are your thoughts on using birch plywood for a subwooder enclosure? How do you think the enclosure would handle flex and can you comment about its tonal qualities? What brought this question to my mind is that MDF really is not a great material for holding fasteners (screws). If you swap your woofer out a few times the screw holes are more or less shot. I was think of using T-nuts or some other threaded insert, and use machine screws to mount the subwoofer. That way the woofer could be removed would damaging the enclosure. Care to brainstorm? Thanks jonblack MDF is ideal for cutting, machining and drilling, since it does not chip easily. On the other hand, plywood is a much more stronger material, which can be used for doors, floors, staircases and outdoor furniture. It is easier to create curved surfaces with plywood, since it bends easily.
