Posted July 19, 201214 yr Hi guys,I currently have two regular pioneer 10" shallow mount subs in the back of my dodge ram. i was planning on upgrading to the the premium pioneer 10"s ( the s4 model) this friday. I have a rocksford fosgate r500 d series amp. the old subs run at around 200-250 rms i belive, and the new ones would run at 300 rms. my amp pushes out 500 raw rms. i am not sure ( despite what they told me at the aduio shop) wether or not my amp will be enough to properly power the new subs. The guy says whenever he does a system with the preium pioneers he uses the r500 amp. However, i'd hate to upgrade only to see a minimal change in performance. does anyone have any kind of experience with this sort of thing?
July 19, 201214 yr You won't notice a thing changing amps. The driver and enclosure change will be all you will tell. They just want more of your hard earned money.
July 19, 201214 yr Author i'm changing the subs. from 2 10's that support 200rms. to 2 10's that support 300 rms. so they can handle more power. my question, is whether or not my amp can support this upgrade. the guys at the shop say it will, but i never make it a habit to blindy trust the salesman. i already have the rocksford fosgat r500 d series amp.
July 19, 201214 yr Of course it can. Just because the new subs can handle more power does not mean they need more power. Even upgrading power, you'd have to double it before you would be able to hear a difference and you probably wouldn't be able to safely throw 1KW at them.
July 19, 201214 yr Author would there be a significant difference in sq or spl when upgrading from the regular to the premium? i was uanble to find anything online comparing the two
July 19, 201214 yr Author im not upgrading the amp. im upgrading the subs from the regular shallow mount pioneers to the premium s4 model. so would i see any significant difference in sq or spl if i went through with this upgrade?
July 19, 201214 yr I know what you are doing. It's very likely you will hear a diifference, but not a guarantee. There are too many variables. I was just giving you an idea of what you are in for.
