Ive been looking into a sp4 18 and have a few questions, hoping to find somone on the fourms instead of flooding fi with emails atm.
Would running a cresendo 3500 to a single 18 sp4 at .7 be to much? Also how many cubes should i go with with 1 18 on 3500 tuned to 32hz.
I would be getting the sub with all the opitions also if that makes a differnce in power handling.
Thanks guys!!
The BC3500 would be fine. I have 4 SP4 18's w/ a BC3500 on each one in a 4th order at .5ohm ea.
If your doing ported, 6-8cu ft would be great. That's if you have it. It'd be best to figure max internal volume you'll have after wood displacement & then tune accordingly.
Agreed ud be fine.
I have two of them on two 3.5k's in a ported C pillar wall in my blazer. It does 53.6
Agreed ud be fine.
agreed
Thanks guys!
NP! Let us know how it goes.
