Posted July 22, 201213 yr im getting a new gcon 12" and just need to build a box for it. i want it ported, specs for the sub are 2.00-2.50cuft @ 28-33hz for ported box and 2.50-3.00 cuft @28- 30hz for ported optimal.... i came across this box diagram for a ssa dcon 12 but im not sure if it would also work for the gcon 12".http://www.soundsolutionsaudio.com/forum/topic/45938-quote-for-225cuft-dcon-enclosure/page__p__726610__fromsearch__1#entry726610if anyone has any dimensions for one could i bum them from you if not a little insight would help, Thanks.
July 22, 201213 yr The pre-designed enclosure offered by SSA for the Icon is 2.5 ft^3 ported. Take a look, this may be what you could use.http://www.soundsolutionsaudio.com/index.php/product-information/icon.html
July 22, 201213 yr Author The pre-designed enclosure offered by SSA for the Icon is 2.5 ft^3 ported. Take a look, this may be what you could use.http://www.soundsolu...ation/icon.htmlDo you know what that box is tuned to? the 2.5ft^3 ported one?
July 31, 201213 yr I suggest going to re audio and using the box calculater it works well that's what me and nem used to build both boxes for my gcon 15
July 31, 201213 yr I suggest going to re audio and using the box calculater it works well that's what me and nem used to build both boxes for my gcon 15The RE calc is horrible.
July 31, 201213 yr I suggest going to re audio and using the box calculater it works well that's what me and nem used to build both boxes for my gcon 15The RE calc is horrible.Agreed
July 31, 201213 yr I suggest going to re audio and using the box calculater it works well that's what me and nem used to build both boxes for my gcon 15It is not the only one I use to model boxes. Always double check one to the next and final figures by hand.
