Posted July 29, 201213 yr I have 2 sa15s and i'm designing a new box. It's a daily driver but i want it to be a very loud daily driver. i currently have a hifonics hfi1500 (pending upgrade) big 3 done, XS Power D925 on the way along with second skin coming. I'm probably going to go around 7.5-8 cubes after displacement and wondering which one will get louder to. If i go aeroport how big and long should i go. Any input is appreciated! Thanks
July 29, 201213 yr I would go with the slot port if there is enough space, reason being is that slot port is more flexible to acheive desired port area.
July 29, 201213 yr Which is louder isn't a question worth discussing. Which will work better for you should be what you are looking into.
July 29, 201213 yr Use a round aero with a tornado in it to increase airflow.Will that also increase db effiiciency?
July 29, 201213 yr I like the flexibility of an aero port, being able to change tuning on the fly for comps.
July 29, 201213 yr If your looking at aero ports take a look at this link and play with the numbers a bit to see if anything works for you. I'll be using an aero in my next box from the little I know using aeros sometimes helps keep the box a bit smaller also here's the linkhttp://www.psp-inc.com/tools.html
