Posted August 7, 201214 yr Specs where provided from an old friend whos been doing SPL and bandpasses for a long time, just wanted to see some other sundown people input, maybe sean will poke his head in here. The specs I was given was 5.7cuft 1:1 50sqin of port area 8" long.After the suggested BP design I "tried" to mock one up in sketch up. I probably got this all wrong but here is a picture of it with some area's left out to view the measurements. I shortened the port based on 1 shared wall, the way I got the length of the port of 5.25" is that I calculated the box like a standard ported box with torres calc at 50sqin 8" long, got the resulted tuning, then changed it to 1 shared wall, accounting for the difference of 4.5Hz I then adjusted the port lower in length till the same (within .01) tuning was obtained. I hope that made sense. Anyway here is the diagram/photo any input would be helpful as this is my first attempt at doing a BP design and I just kinda winged it based on the data given to me of 1:1 with 50sqin of port area 8" long.The box is 1:1 2.9cuft sealed, 2.9cuft ported 50sqin of port area shortened the port length as detailed above.Input? Edited August 7, 201214 yr by All4Spl
August 8, 201214 yr Have you modeled it yet? Taking a stab with a ratio of ported to sealed and choosing a vent is meaningless. Just going by the ratio is very meaningless.You need to get the T/S parameters of those drivers and plug-n-chug in a modeling program. This is the only way you can see if what you are doing is going to work.
