Posted August 9, 201214 yr We are currently out of stock on carrying cases because we are in the process of switching over to another case that should remain permanent and more user friendly.Our past cases, I personally feel, were too small for some of our larger product equipment such as LCD Meter, USB Pro Meter and unsafe for transport for RTA Pro and SQL Meter.We are about to start stocking our new cases within the next couple weeks that will prohibit the strain of running out of internal space!We will be stocking 2 different carrying case that are designated for specific devices.When ordering USB, USB Noise, RTA Pro, SQL or Bluetooth meter, adding a carrying case with it will sufficiently hold these devices.The USB, USB Noise and Bluetooth meter will set in the middle of the case with it's USB cable wrapped around the meter.The low thickness of the case itself prevents the meter from moving out of it's location even when shaken violently.The RTA Pro and SQL Meter are long and cylindrical devices which can roll.They will be placed in this same case in it's own designated spot to prevent movement while still able to hold your USB Cable inside the case.The LCD Meter and USB Pro Meter come with the most items and because of this has caused past problems with getting everything back in the case once it's been used...Fear no more! The larger cases for these 2 meters are extra large and will be able to store these 2 devices hardware with plenty of space!All hardware from these 2 meters will have their own designated spaces in the case for a more professional look.This large case is approximately 18" long whereas the smaller case for all other meters is 12" long.Due to the case change, the case PRICING has also changed.Previous case pricing when adding a case to an order was $25.Upcoming carrying case prices are as follows-When adding case to order(we currently do not have these yet),Cases for ALL Meters EXCEPT LCD and USB Pro- $30 add-onCases for LCD and USB Pro Meter - $50 add-onIf ordering case separately without a measuring device-Small case- $45Large case- $70These prices will be updated to our retailers, etc once they are in stock.
