So you have - to - to - on the amp and + to + to + on the amp? Can't tell from the pics.
  • Replies 105
  • Views 10.5k
  • Aaron Clinton
    Aaron Clinton
    Loud is relative to the person and the install. There are a number of factors at play here that effect the output. How much sound is allowed to pass through from the rear into the cabin, what kind o
  • Notorious97200
    Notorious97200
    Maybe you expect too much out of a single sealed 12" ? Some ideas ; Try a ported box. Use aeroports too save space if the trunk is small. Change box position : fire the sub through the rear. more p
  • 1w
Ya the negative to negative and positive to positive and then the ones with two have it going to the amp
I know it is in parrel now cause everyone said to do its so it would be loud and it's not much louder
Please take some photos of the sub woofer where you think there is noise occurring. If there is something actually hitting and not an air leak, there will be a mark or some sort of damage from impact.
Clearance is not an issue on the Xcon despite the large throw or what inferior brands want to believe about the 12-spoke basket.
Okay I will take pics later today. I might have to mle a video of it doing it because I didn't see any damage
welll i cant figure out how to upload the pictures.
Dont feel bad it took me months to learn.
Oh alright. Ya idk what's doing the noise thing. But I will hopefully find out soon
Cause I would love to show of my system to people so that I am get some more ssa subs in the valley. But I can't shows this off right now and it also doesn't allowe me to show of for my box business. Just a hold up that is annoying. Cause I have seen the videos of what this sub does
It's a two ohm dvc sub
Wire it the same way but you will have four ohms. use dmm and check what you have coming ot of the box with out the sub being hooked up.
WHich is fine, your final load will be 1ohm not .5.
4 ohm for series
Ya I know that's how it is hooked up. At 1 ohm. I mean the sub is moving I'll put a video of that noise and the part of the cone inverting today
4 ohm for series
Correct, but I was using the picture posted and his D2 wired in the same mannor.
4 ohm for series
Wont you say he should double check with a dmm.
4 ohm for series
You say there is a mark on the dust cap?
4 ohm for series
Yes, always double check. No matter how good you are, mistakes will always be made. fing34.gif
Okay something wierd is happening it looks like something is hit the sub from the inside when it makes that noise I dents right above the word Xcon. But nothing is there. And here are the pics
There is something there to make a mark on the dust cap..
I didn't say there is a mark Aaron said if its hitting something the there will be a mark. But I didn't see one and no there isn't anything in the way
