August 15, 201214 yr Author i'm buying the baffles online. I'm trying to make sure what i'm buying is going to work before i spend the money douche. If youre gonna be an arseho then don't help its pretty simple
August 16, 201214 yr Popular Post Just an FYI, this is seriously car audio 101. Considering your attitude a wee bit of searching might be in order and would net you better responses. The only douche in the thread is the one copping an attitude to rudimentary replies. As a reminder, you agreed to search before posting a thread on this forum. Perhaps you should keep your promise. It would definitely make your threads more useful not only to you but to others who end up searching and reading them.
August 16, 201214 yr Just pay a shop, you may not be quite smart enough to figure this out with the instructions given. lol
August 16, 201214 yr Author I did the measurement. I was just double checking before purchase to make sure that they would work. I didn't want the baffles to show up and have something happen. Nothing wrong with double checking right?
August 16, 201214 yr I did the measurement. I was just double checking before purchase to make sure that they would work. I didn't want the baffles to show up and have something happen. Nothing wrong with double checking right? Always a good thing to double check your work especially if can cost you if you screw stuff up.
August 16, 201214 yr Check the cutout and outside diameter to make sure it will fit (sometimes a bit of mod is required), also the thickness required.
