I built a sealed box for my E8V2 using the recommend cubic feet from the website of .25 and the sub just sounds restricted.
Now I am gonna build a vented enclosure for the sub but lost on the port size.
Every calculator that I use shows a 12" (w) x 2" (h) port being around 85" (L) tuned at 35hz with a volume of .6Vb.
That just does not sound right to me, so where am i going wrong?
Any help would be appreciated.
If that is for one 8" that port is a tad large. Using Small's minimum port formula you'll need apprx. 9.75 in^2 of port area. With a .6 ft^3 box that port will need to be 33" long.
Yes that is for one 8" sub. I did not think the calculators where all that complicated but apparently I don't know how to use or interpret them properly.
Thanks for the info.
that is ASSuMEing I was using the right sub. The lower end sundown 8?
