November 12, 201213 yr Author steel bracing on all 8 cornerscar is in primer at lastsmoothed off the fog lights3liters of fiberglass and resin mix in the whole top half of doorbus bar finally done might give it a polish when i have time just need need to make perspex box for it nownow this is the reason you dont leave the keys in the car i leave the car is reverse as it has no hand brake.duncan decided to start the car it shoot back 10ft into 10 of the subs and a wall : damage to the cardamage to 1 subfunny how the subs aint even in the car yet and there destroying it :L
December 19, 201212 yr Author well cuple more bits been going on car is now ready for paint and the main box is nearly done just a little more steel todothen cuple coats of fiberglass once thats done i can get the tunnel finished and get it in the car for good and get it fullysealed up and start running wiringthink we are going to go for the brushed look as not a fan of the bling bling polished looknot sure what the plan for the roof is might wrap it in matt blackwell little teaser as the pics aint great but will get some decent pics once i put the car back together and it isnt dark the blueis brighter in person
December 19, 201212 yr Admin Heck of a build, keep the pictures coming. Crazy how much money is going into such a small commuter car.
January 8, 201312 yr Author thanks guys heres another little updategetting there just needs side skirts, door lock, wheels and the roof ect wraping plus we will be changing the lights for tinted ones got a little delivery 8 amps 9,000rms for the c2 and 3,500rms for my saxonext step carry on with the audio on the c2
January 8, 201312 yr One of if not the most impressive enclosure I have seen. This thing should be nuts!
May 11, 201312 yr Author thanks guys well I have lots and lots of pics to post but I will still off with a cuple until tomorrow
May 21, 201312 yr I was just about to ask about them. How do they perform. I notice they say German, but they have some Korean ques as well.
June 6, 201312 yr Author thanks guys amps seem to be running very well even with my dropping them down to 11s (car still has standard 70amp alt at the moment)well about time I updated this car had mot today only a cuple things that have failed mainly due to bits being robbed off it but easy fix so mot pretty much sorted I havnt had much time to work on the c2 due to family problems so for mod nats it wont look pretty but aslong as it has bass I will be happy34hz without front end of portmosconi 4 to 6 and epic fitted36mm birch ply and 50x50x6mm angle iron this shouldnt flexseat belts fittedbass over leg space
June 6, 201312 yr Author a little vid wasn't full tilt and tunning it as 34hz not the 29hz its going to be quite windy
June 6, 201312 yr This is amazing ! You have good skills, sir I'm waiting for more... I can tell you this French car is small, VERY small !!! It's a C2, but the C1 is even smaller.
June 17, 201312 yr Author thanks bud well a little video from yesterday I think we might need to get the stripper pole inside asap 12-16mm of deadening isn't holding up to well http://www.facebook.com/photo.php?v=10151695267410763&l=5526063826142189557 Edited June 17, 201312 yr by liam_b
