Posted October 7, 201212 yr So i currently have an aq2200 and i am wanting to get more power. So i was thinking about selling or trading my current amp for either a crescendo bc3500 or an aq3500. But i was thinking maybe i should just buy another aq2200 and strap them. Only thing is i have no clue on how to do this and would not want to mess things up. Is it hard to strap amps and would it be worth to strap them?
October 7, 201212 yr What subs do you have? Why do you want more power? What does your electrical system consist of?
October 7, 201212 yr Author I am looking into different subs. more power to get louder. i have singer alt 230amp yellow top at front xp3000 at rear
October 7, 201212 yr IMO don't waste your money, unless you are actually competing in SPL.Difference between 2200w and 3500w is 2db before power compression, so you'll be lucky if the difference is even audible. Chances are very good it won't be.Buying a 2nd 2200 and strapping them or running one per sub would be a 3db difference before power compression, possible it would be audible depending on circumstances but is it worth $400 plus the cost of wiring, the time installing, etc for something that might be audible (it very well might not be if depending on power compression), and if it is audible isn't a significant audible difference?If you're trying to get louder, power is the least effective and efficient means of doing so.
October 8, 201212 yr What subs do you have? What box are they in? What is your budget? How much room do you have? Did you do any sound deadening?If you answer those questions we can give you more specifics, but your box is going to be a very large factor in determining your loudness.
October 8, 201212 yr so to get louder i should look at subs? i was thinking the xcon 12'sThose xcons would get plenty loud with that aq2200 @ 1 ohm. Using the proper box! Edited October 8, 201212 yr by pmureika
October 8, 201212 yr i use ramdesigns, and i have a local guy here in san marcos that does all my wood work for me. hes cold. and proven i have been competing in usaci for 3 years and streetspl for 1, never had a box blow out,before i found him i was always sad from blow outs.
October 8, 201212 yr one of my old boxs is for sale its for 2 15's.... not sure wwhat your running yet you seem to be in the air about everything
October 8, 201212 yr one of my old boxs is for sale its for 2 15's.... not sure wwhat your running yet you seem to be in the air about everythingHe has a ford escape not much room in there.
October 8, 201212 yr one of my old boxs is for sale its for 2 15's.... not sure wwhat your running yet you seem to be in the air about everythingHe has a ford escape not much room in there. for some reason i was reading ford exploerer
October 8, 201212 yr one of my old boxs is for sale its for 2 15's.... not sure wwhat your running yet you seem to be in the air about everythingHe has a ford escape not much room in there. for some reason i was reading ford exploererAlmost the same.lol
October 8, 201212 yr so to get louder i should look at subs? i was thinking the xcon 12'syou should learn to build and design your own boxes and do testing on different firing and placement positions.
October 8, 201212 yr I used ram design for my brother ford escort 95~ i believe trhe year was. It was 2 SA12's in a ported enclosure!http://www.ram-designs.com/quote.phpthat is his link for a quote and here is what my brother and I made from it!
