Posted October 10, 201214 yr Picked up a Re XTX 5000.1 to run a 15" Z V.3. Right now i'm running a rockford t400-4 to 2 sets of t1675-s. I just put a new 170amp H.O alt and my lights are already dimming. With the new sub arriving friday i will be putting the Re in and don't think this batt will hold up. Any suggestions on a good batt that will keep this thing running smooth?
October 10, 201214 yr I would say a yellow top for up front and a 2400 or an xs and i would finish the big 3
October 10, 201214 yr I would say a yellow top for up front and a 2400 or an xs and i would finish the big 3why a yellow top?
October 10, 201214 yr I would say a yellow top for up front and a 2400 or an xs and i would finish the big 3why a yellow top?just a suggestion or better yet he could do a khc 1200 up front
October 11, 201214 yr You really need to upgrade the grounds as well.I'm a big fan of the Diehard Platinum. For a little cheaper I'd go for a Deka Intimdator/rebadge.
October 12, 201214 yr Great, I'm looking for a strong under hood battery also! This post is right on time BigShug!! A great way to make an entrance!!! Welcome
October 12, 201214 yr I would also say finish the big 3 first, with just power wire your bottlenecking.batteries go with what you can afford.
October 15, 201214 yr Welcome aboard!!!! see how much drop you get and if voltage gets to low maybe add a xspower D1200 in the trunk. Good luck!
October 15, 201214 yr Picked up a Re XTX 5000.1 to run a 15" Z V.3. Right now i'm running a rockford t400-4 to 2 sets of t1675-s. I just put a new 170amp H.O alt and my lights are already dimming. With the new sub arriving friday i will be putting the Re in and don't think this batt will hold up. Any suggestions on a good batt that will keep this thing running smooth?You can take lights such as led lights which consumes much less battery.
