Posted March 23, 200620 yr I know what you're thinking, but it's not the typical noob question. I'm wondering how the coils are wound on a DVC speaker/sub. Are they wound with one above the other, is one on top of the other? Jimj and i were discussing this earlier, maybe someone here will know. here's the thoughts so far...One above the other is wrong cause this is just a split coil, if there's no gap then the coils are touching shorting and acting as one coil, not twoOne wound on top of the first--They'd touch stillThe only thing is maybe they have some sort of thin insulation, but under the heat conditions i don't see this as being very effective
March 29, 200619 yr Sweet, I've been wondering about how that worked, but never got around to postin it.
March 29, 200619 yr Author I know i'm going to get pwnt on this, and i kinda hope i do, but if one is on top of the other, wouldn't one coil behave differently from the other, especially if they're both powered at the same time?
April 2, 200619 yr thought they where wount side by side, as in the individual wires side by side, not the entire coil. My misonception i geuss. I may have to go buy a cheap DVC driver to tear it apart to verify one wya or the other.One of top of the other would cause differences but as long as the coil's wire length is the same and size is reletively the same and windings are the same i geuss the differnces would be no more than the 15% differnece in any given driver's T/S parameters from the test batch for the T/S parameters.
