Posted October 22, 201212 yr ok guys one my home from work my friends subs im using Kenwoods 12" 400 rms each stop working as soon as i get ready to pull in. i look under my hood and my power wire fuse holder looks like it blew up.... kinda in half.... ( I was only using these subs for a week until i get my FI SSD 15 today or tomorrow.) Any ideas why this happened? i had a spare KIcker 4 awg wire so i wasnt to mad lol.
October 22, 201212 yr Not relevant to Fi.Is any of the fuse holder melted? Did it have a plastic protective case over the metal and fuse? I'm guessing it popped off, or something, and it short-circuited.
October 22, 201212 yr Author Not relevant to Fi.Is any of the fuse holder melted? Did it have a plastic protective case over the metal and fuse? I'm guessing it popped off, or something, and it short-circuited.yeah fuse holder melted and the plastic case kinda look like it blew in half
October 22, 201212 yr I would check all other connections on battery(s), amps, etc. Then mount a new fuseholder. Where was the old one mounted?
October 22, 201212 yr Sounds like a loose connection that heated up and caused a meltdown.Though pictures would be helpful. Also make sure it's not mounted near any heat source....i.e. close to exhaust manifolds, etc.
October 23, 201212 yr Author thanks guys I think the cause was just the power wire was cheap (http://www.amazon.com/gp/product/B000Q6DLTK/ref=oh_details_o01_s00_i00) I think the amp was asking to much of this wire.
October 23, 201212 yr Didn't click on the link, but in reality wire is wire. 999 out of 1000 times it is an installation that causes what you had happen...
October 23, 201212 yr thanks guys I think the cause was just the power wire was cheap (http://www.amazon.co...ils_o01_s00_i00) I think the amp was asking to much of this wire.If the problem was the wire, then the wire would have failed or fuse would have blown, not the fuse holder as in your circumstance.
October 23, 201212 yr Author The fuse was blown as well and i checked I didnt find anything wrong for it to blow like this
October 23, 201212 yr The fuse holder still wouldn't have had a meltdown.I know you don't want to believe it, but this was more than likely install related.
October 23, 201212 yr If the fuse blew, then no current would have been traveling through the wire anymore.For the fuse holder to melt, you would have had to had too large a fuse for that cable in the fuse holder causing the wire to heat, melt the terminal to the fuse holder, etc... or a loose connection at the fuse holder or the fuse holder itself andor along with the terminal to be made of a material not conductive enough for such current transfer(which i doubt in this case).Look for any other signs of melting or burn marks at every end of the power cable all the way to battery and amp, check ground connections and speaker outputs on amp.Also check fusing on amp and see if they blew too.
October 23, 201212 yr I think i can shed some light on this.Back back back in the day i had a jbl 1200, i got an 10$ANL fuse holder and i swear every couple months it would melt and i would have to get a new one. Mind you this was wire going into plastic piece being held down by a bolt. The audio store kept trying to get me to buy the exspensive one but i was determined to make my own lol.Now adays ring terminals and better still 10$ fuse holders actually eliminate that problem, but i have had that happen to me in the past.
October 24, 201212 yr Author My amp was perfectly fine nothing wrong with it, this was just the wire.
October 24, 201212 yr Author Oh and i have one more question. When im parked or just not moving and i turn my radio up sometimes the radio cuts off then cuts back on. This never happens when im driving though. I have 10 speakers and 1 sub hooked up to my deck. 5 of them are tweeters. 2 are 6 by 9 and 2 6 by 8 and 1 horn. Oh and 1 FI SSD 15.
October 24, 201212 yr If all those speakers are hooked up directly to your headunit without an amp then expect for your radio or its outputs to get destroyed too.
October 24, 201212 yr Popular Post Sorry guy, but your system sounds like a total mess. I think it's time to pull everything and start over from scratch. Not trying to be a jerk.
October 24, 201212 yr Author I think it has something to do with my alternator or battery and i have my 4 door speakers hooked up to my deck and then my others ran off my door speakers
October 24, 201212 yr check your voltage before and after your fuse holder, with the music playing. It should be the same.
October 24, 201212 yr Yeah, that's bad. You should go to www.bcae1.com and do some research. You really need to start over.
October 24, 201212 yr Was it an agu fuse holder. Cheap agu fuses have bad soldered ends that cause heat build up making the fuse holders melt.
October 24, 201212 yr I think it has something to do with my alternator or battery and i have my 4 door speakers hooked up to my deck and then my others ran off my door speakersFirst, your system needs entirely redesigned. That's not a good system layout at all.Second, how do you have them wired? I would agree with jay-cee that it's likely you are simply overdriving the internal amplifier in the headunit. Even then I wouldn't recommend an amp, first I would recommend you eliminate 60% of your speakers.
October 25, 201212 yr Author I think it has something to do with my alternator or battery and i have my 4 door speakers hooked up to my deck and then my others ran off my door speakersFirst, your system needs entirely redesigned. That's not a good system layout at all.Second, how do you have them wired? I would agree with jay-cee that it's likely you are simply overdriving the internal amplifier in the headunit. Even then I wouldn't recommend an amp, first I would recommend you eliminate 60% of your speakers.and what do you think would be good for my system?
