Posted October 23, 201213 yr Had a 12" Fi BTL off 2500RMS in a 2.70cuft box @ 30Hz. Trunk setup.Have a different car now and was thinking 2x15" @ 600RMS each, sealed in rear seat area, facing forward (or backward).Was looking at RE Audio SEX series.Just wondering how it would compare to the BTL.Would the two 15's move more air?How would the lows be, and of course SQ difference be?
October 23, 201213 yr Re is garbage, and putting a couple hundred pounds of projectiles in your back seat isn't a good idea.
October 23, 201213 yr Author Sealed box for the 15's would be around recommended specs that is 1.5-2.0 per woofer, of course I'd go bigger, probably 2.5cuft unless someone suggests otherwise.
October 23, 201213 yr unless someone suggests otherwise.Do something else. What are your goals? What vehicle? Budget?
October 23, 201213 yr Author I don't care about loud, I want something that sounds good, where I can enjoy listening to the music and not just be obsessed over a few songs that sound optimal. Moving some air would be great too.
October 23, 201213 yr Author unless someone suggests otherwise.Do something else. What are your goals? What vehicle? Budget?2005 Civic Coupe.Just posted goals. I'm doing entire system but budget for sub/s amp would be about $700.
October 23, 201213 yr Author What didn't you like about the BTL?Oh, it was impressive.Maybe it's just me but I found that I listened to the same tracks on OCD repeat.Stock stereo in Civic right now, and find that I've been able to actually enjoy the music, rather that the result of it, if that makes sense. Edited October 23, 201213 yr by b34tBoX
October 23, 201213 yr I would definitely recommend keeping things in the trunk. Two twelves sealed would be a good option. Look at the SSA GCON's or Fi SSD's, both work very well sealed. Maybe a single 15 like the Fi Q or SSA ICON would be great too.
October 23, 201213 yr Author I would definitely recommend keeping things in the trunk. Two twelves sealed would be a good option. Look at the SSA GCON's or Fi SSD's, both work very well sealed. Maybe a single 15 like the Fi Q or SSA ICON would be great too.The trunks on these cars hold no air in, and I don't like the feeling of all that weight at the back of the vehicle.What's a disadvantage to having the woofers in cabin?
October 23, 201213 yr What didn't you like about the BTL?Oh, it was impressive.Maybe it's just me but I found that I listened to the same tracks on OCD repeat.Stock stereo in Civic right now, and find that I've been able to actually enjoy the music, rather that the result of it, if that makes sense.It makes perfect sense, some songs have more bass content than others. Also some songs will peak differently in your car than others.
October 23, 201213 yr What's a disadvantage to having the woofers in cabin?Serious injury or death, turning your 5 seat vehicle into a 2 seat vehicle, unless you seal it completely off from the trunk output will suffer, easier to see (thieves), and lastly it looks like shit.
October 23, 201213 yr Author The '05 civic is my weekend car, I park it in garage, not too worried about theft.I was also considering 2x15" Obsidian in sealed, according to T/S they should do well.Enclosure would be well secured, no worries, and I make it look nice.The front baffle will be at the same angle as the front seats. With each subwoofer behind driver/passenger seat and adequate breathing room.Yes, I will be sealing it from the trunk. Edited October 23, 201213 yr by b34tBoX
October 23, 201213 yr I don't care about loud, I want something that sounds good, where I can enjoy listening to the music and not just be obsessed over a few songs that sound optimal. Moving some air would be great too.You don't care about loud but you want to move air???What didn't you like about the BTL?Oh, it was impressive.Maybe it's just me but I found that I listened to the same tracks on OCD repeat.Stock stereo in Civic right now, and find that I've been able to actually enjoy the music, rather that the result of it, if that makes sense.Huh? You are changing subs because you only listened to a couple songs? If so, easy cure. Turn down the bass.
October 23, 201213 yr Author Loud is not a priority to me, I'm just wondering how much air would be moved with 2x15's @ 600RMS each sealed compared to one 12" ported at 2000RMS.I ran the BTL for two years and listened to just about everything through it. I guess I just became obsessed with finding the songs that sounded best through it in my vehicle.
October 28, 201213 yr I would definitely recommend keeping things in the trunk. Two twelves sealed would be a good option. Look at the SSA GCON's or Fi SSD's, both work very well sealed. Maybe a single 15 like the Fi Q or SSA ICON would be great too.The trunks on these cars hold no air in, and I don't like the feeling of all that weight at the back of the vehicle.What's a disadvantage to having the woofers in cabin?Considering the weight distribution of that vehicle is approximately 60-40, "all that weight at the back of the vehicle" will actually help to balance the car and improve handling and feel. You may think that you're drivers will be well-secured, but once you get in an accident you'll quickly learn how unsecured they actually are.
October 28, 201213 yr Author I'm good, build it big enough so it doesn't move. No really, I'm confident I can build it secure enough, besides, I don't drive this car much, and do you tell everyone that who has audio equipment in cabin? Edited October 28, 201213 yr by b34tBoX
October 28, 201213 yr What didn't you like about the BTL?Oh, it was impressive.Maybe it's just me but I found that I listened to the same tracks on OCD repeat.Stock stereo in Civic right now, and find that I've been able to actually enjoy the music, rather that the result of it, if that makes sense.How is your sub amp connected to your stock stereo?It looks as if you have a huge peak in your response that is only sounding good on certain songs that you are unable to tame.
October 28, 201213 yr I'm good, build it big enough so it doesn't move. No really, I'm confident I can build it secure enough, besides, I don't drive this car much, and do you tell everyone that who has audio equipment in cabin?I sure do. Growing up with a father with a towing company and seeing many many accidents opens your eyes to things. You THINK you can make it secure, but remember, you have no control over physics when an accident occurs. I've seen enclosures that were bolted to a trunk get ripped right through a back seat, seats fly out of vehicles, you name it. It's never safe, no matter what you think.
October 28, 201213 yr Author What didn't you like about the BTL?Oh, it was impressive.Maybe it's just me but I found that I listened to the same tracks on OCD repeat.Stock stereo in Civic right now, and find that I've been able to actually enjoy the music, rather that the result of it, if that makes sense.How is your sub amp connected to your stock stereo?It looks as if you have a huge peak in your response that is only sounding good on certain songs that you are unable to tame.That was a previous setup. I built three enclosures for the BTL ranging from different sizes and tuning frequencies, all sounded great in their own way.Listen, it's just how we all have our favorite demo songs, that sound 100% on our builds. There was nothing lacking, maybe I'm just looking for a flatter response or more woofer control.Audio:Alpine 9885270A DC Power large body alternatorOptima Red Top (front)Optima Yellow Top (rear)Knu Konceptz Kolossus Fleks Power Kable (All Copper)Knu Konceptz Krystal RCA KablesKnu Konceptz Klear Speaker Kable2 sets of CDT CL-62 6.5" components with silk-dome tweeters (front)CDT CL-69X (rear)12" Fi BTL (D2, Cooling, HiXmCoil, Daily))Soundstream Rubicon 1.2500DSoundstream Rubicon 2.600Soundstream Rubicon 2.250Some pics:
October 28, 201213 yr Have you tried to fire the box through the cabin ? Sealed off from the trunk ?Nice setup OP !
