October 26, 201214 yr Looks sexy specially the stain par! video of the beast at work never seen a cnc machine work before!
October 26, 201214 yr Well since you are here trying to make money. These kits can be easily found online. By the looks of the parts this is more than likely just a kit you purchased and are now just going to use the machine you are building to copy the kit you purchased and sell them to others. Please correct me if I'm wrong. I'm just assuming due to your post count.
October 26, 201214 yr Well since you are here trying to make money. These kits can be easily found online. By the looks of the parts this is more than likely just a kit you purchased and are now just going to use the machine you are building to copy the kit you purchased and sell them to others.Please correct me if I'm wrong. I'm just assuming due to your post count.Interesting, I never looked into those kits before. However, after your mentioning it(and doing some quick research) I can see where you could ask that.
October 26, 201214 yr Author Well since you are here trying to make money. These kits can be easily found online. By the looks of the parts this is more than likely just a kit you purchased and are now just going to use the machine you are building to copy the kit you purchased and sell them to others.Please correct me if I'm wrong. I'm just assuming due to your post count.no this was designed by me, and i had the parts cut out on a cnc at a local cabinet shop, this is an organic design, that im still improving uponand ive actually been a member since 2009, lurking, and i have been a competitor since 2007 in SS3-4 with db scores of around 155-158 using atomic APXX 18's and atomic 5k's Edited October 26, 201214 yr by ak11667
November 2, 201213 yr Author been a while since last update, i was just waiting on parts, but my pc fried the controller board, my fault for buying chinese, so i got a new one coming, but i managed to get this video in before it fried
November 2, 201213 yr Author I was having a good time with it, but then the boar went up in smoke and then 20minutes later my servers hard drive smoked too, today cost me just over 400dollars and 8tb of data
November 2, 201213 yr I was having a good time with it, but then the boar went up in smoke and then 20minutes later my servers hard drive smoked too, today cost me just over 400dollars and 8tb of dataDamn that sucks, hope you get it all sorted out.
November 5, 201213 yr Author mounted the router and the end mill todayive also ordered a new controller board and i will be ordering a even better one later this week that will increase my accuracy drastically
