Posted March 27, 200619 yr I checked all the pressure in the tires of the 3 vehicles that are at my houseNot a single one was at the right PSI.Some 20lbs over, some 10lbs under.Its crazy how much air you can loose in your tires in a matter of months. And if you just fill them up when they are low use a pressure gauge, eyeballing and using the built in gauge from the has station are not accurate.Go buy one, they arent that expensiveI know it sounds lame but if kept neglected ( like what i did) you can really kill your mileage and get some nice uneven tire wear.
March 27, 200619 yr the stratus used to be extremely sensitive to air pressure, i could watch the MPG drop big time when the pressure got anything more than 3-5lbs low
March 27, 200619 yr Especially in colder climates!Check your tire pressure as part of a weekly schedule.
March 27, 200619 yr Admin I should check the sled since it really has not moved since the SWVA meet #2
March 27, 200619 yr Deflated.I bought one of those air pressure nozzles for my compressor with a built in gauge, it makes it way easier especially when you have 3 cars, 2 trailers, a motorcycle and some other she-i-o.
