Posted December 2, 201213 yr (1) sp4 18 vs (2) bl 15'sGoing to be run most likely by a hifonics Brutus 2400.1 amp with custom box. Will be used as a daily driver and I listen to mostly rap I'm just curious to hear some input. It's going to be in a Toyota camry so a closed trunk if that makes any difference to anyone. Thanks
December 2, 201213 yr how do you plan on fitting any of those in your Camry?also this thread be locked for being a "vs" thread.
December 2, 201213 yr how do you plan on fitting any of those in your Camry?also this thread be locked for being a "vs" thread.Thread wont be locked cause its a "vs" thread.You wont fit either in that trunk, look at a Fi SP4 15" or 2-Fi Bl 12"s. Usually more cone area and power compression is a plus in a daily driver but its not a factor in which will be louder. The only way to find out whats louder is to buy both and install then meter them in your install. Just flip a coin and go from there.
December 2, 201213 yr Author Lol well my trunk is huge I haven't really checked for the 18 box but the box for 2 15's had plenty of extra room. And sorry I didn't know I couldn't make a vs thread this is my first post. Anyway I'm still thinking about it. It's a 98 camry by the way
December 2, 201213 yr I dont think it would be a bad idea for you to go with the fi 15 sp4. i just installed mine last night in my altima and it sounds incredible by itself.
December 2, 201213 yr Author 45w X 18h is the back part55w X 20h is the front partBoth measurements are shortened a little give or takeI have a picture but idk how to post it using my phoneBut I'm thinking at least 2 15's would fit so in that case 1 sp4 or 2 bl's? Edited December 2, 201213 yr by Iamjmm
December 2, 201213 yr damn thats huge... what about the opening?This. Unless you're building it in the trunk, it's not happening imo.
December 2, 201213 yr Author Trunk opening is 20" by 38"And because of the shape of my trunk I think I could fit 2 15's by putting in 1 side at a time. 1 18 will fit but I'm not sure about 2 15's yet. My cousins gonna come try his but idk what to get still lol Edited December 2, 201213 yr by Iamjmm
