Posted December 5, 201213 yr I cant find one to save my life. Ive sanded and sanded and cant find a place. Anyone know any tricks?
December 5, 201213 yr I cant find one to save my life. Ive sanded and sanded and cant find a place. Anyone know any tricks?If the truck has a frame use it.If you did the big three. Edited December 5, 201213 yr by pmureika
December 5, 201213 yr Author 2003 tacoma guess id need to cut more jumpers to reach from bat to amp haha lol
December 5, 201213 yr 2003 tacoma guess id need to cut more jumpers to reach from bat to amp haha lolPlease tell me you are not using jumper cables as you power wiring?
December 5, 201213 yr Author No just ground lol. In a jam atm and not long enough and my frames not working i cant get any signal. Power on amp comes on and flashes back off.
December 5, 201213 yr 2003 tacoma guess id need to cut more jumpers to reach from bat to amp haha lolPlease tell me you are not using jumper cables as you power wiring?That made me lol. I sure hope not.
December 5, 201213 yr No just ground lol. In a jam atm and not long enough and my frames not working i cant get any signal. Power on amp comes on and flashes back off.Oh dear god...
December 5, 201213 yr No just ground lol. In a jam atm and not long enough and my frames not working i cant get any signal. Power on amp comes on and flashes back off.Buy a cheap dmm, it sounds like more then a ground problem.
December 5, 201213 yr Author What could be the problem? If its a grounding issue? No experience with that
December 5, 201213 yr Stop and find someone who is knowlegable before you ruin your audio equipment or your truck...
December 5, 201213 yr Stop and find someone who is knowlegable before you ruin your audio equipment or your truck...^^^ He is correct !
December 5, 201213 yr Author I mean what could be the problem? Alton here on ssa said i could use jumper cable wire for ground since my other ground wire wasnt long at all . Could i just run the ground to battery then to amp?
December 5, 201213 yr Its a truck, use the frameDo not use the frame.....I have an 01 Tacoma, same as his 03These have the shittiest frames, idk what it is but they had a recall on them. They'd rust to nothingStraight off the front battery is the best in these
December 5, 201213 yr Author Great thanks alot tim to the neg on bat right? And yes frame is shitty lol rusty but truck is in good shape.
December 6, 201213 yr Author Yes just a small two.chan I'm bridging for now on my sub till my other amp comes in. Use 10 guage jumper cable as ground as i didnt havr rnough ground wire lol.
December 6, 201213 yr A 10 gauge ground? How about don't run anything until you do it correctly? Ever think about that? Lol
December 6, 201213 yr Its just a small 2 chan that wouldnt be enough man? Yes mann , make sure you have fuse on your positive run.
