Posted December 22, 201212 yr I'm in need of posts to use to install the battery. I have a 2000 Acura integra ls which I'm trying to install a 5100r but can't find the correct terminal posts to use. Any advice where I can get them? Thanks
December 23, 201212 yr what kind of posts are you wanting? You can get some bolts from any hardware store (m6), is that what you're talking about?Or you can check out what is offered here. http://store.soundsolutionsaudio.com/categories/batteries-and-electrical/xs-power/accessories.html
December 23, 201212 yr Author I just need regular old posts to hook up the integras OEM terminals onto. I tried looking and battery did come with some screws but I can't used them with the OEM terminals. Edited December 23, 201212 yr by oakteg21
December 23, 201212 yr this should work for youhttp://store.soundsolutionsaudio.com/products/xs-power-580-short-brass-post-adapters-m6.htmlor thesehttp://www.sonicelectronix.com/item_8425_Kinetik-HC-TP-KHCTP-HCTP-KHC-TP.html
December 25, 201212 yr Author this should work for youhttp://store.soundsolutionsaudio.com/products/xs-power-580-short-brass-post-adapters-m6.htmlor thesehttp://www.sonicelectronix.com/item_8425_Kinetik-HC-TP-KHCTP-HCTP-KHC-TP.htmlThanks im going to try the xs power ones
December 28, 201212 yr Author Thank you I took a huge guess and went with the 580 I'm sure glad to hear I made a good guess
