Posted January 1, 201312 yr so im trying to figure out how to design my own boxes and learn how to use these calculators need advice on how this looks like if its right or wrong please. im looking to build a enclousre with subs up port back going into my hatchback integra. subs i will be using are 3 skar vvx 8s. ive had a couple other threads with this same thing but since i have limited space to use and want to try a aero port now. want it to be tuned either 32 hz or 33hz not sure i want to hit the lows i mostly listen to rap/hip hop and some rock but mostly rap/hip hop. please take a look and give me advice on what you guys think thanks. Edited January 1, 201312 yr by oakteg21
January 1, 201312 yr Author A 2" port is not going to work.so what would work? what would be the smallest aero port i could use?could i use a 3" port with a length of 5.75"? Edited January 1, 201312 yr by oakteg21
January 1, 201312 yr Author What is the Xmax on those?skar audio doesnt have it displayed anywhere ive looked for it and cant find it anywhere
January 1, 201312 yr What is the Xmax on those?skar audio doesnt have it displayed anywhere ive looked for it and cant find it anywhereWon't expect any better form that company.
January 1, 201312 yr What is the Xmax on those?skar audio doesnt have it displayed anywhere ive looked for it and cant find it anywhereHmmm...
January 2, 201312 yr Author What is the Xmax on those?skar audio doesnt have it displayed anywhere ive looked for it and cant find it anywhereHmmm...What is the Xmax on those?skar audio doesnt have it displayed anywhere ive looked for it and cant find it anywhereHmmm...what can i do in that situation?
January 2, 201312 yr I guess you can just wing it. Personally I would never buy a sub from a manufacturer that doesn't list proper specs for their drivers.
January 2, 201312 yr Author I guess you can just wing it. Personally I would never buy a sub from a manufacturer that doesn't list proper specs for their drivers.yea i know ive learned my lesson i regret buying them they are still on their boxes new wish i was able to return them but im stuck with them atleast would like for them to be 2 10s instead i made a mistake getting this since i like getting loud and feel the bass hit hard and starting to doubt i will be able to do this with these.
January 2, 201312 yr Author Sorry should have specified mark lafountain ssa member and Im guessing owner of ssa.
January 2, 201312 yr To make things easy I'd say to use at the very least a 4" port. I would shoot for 20+ square inches though, if you can.
January 2, 201312 yr Author So what are the right numbers to use and equations to make the right calculations?
January 2, 201312 yr 4" x 20+" Aero port? Is the torres calculator that off?No man I meant port area, ONLY the opening of the port not the depth.
January 2, 201312 yr Oh ok I wouldn't be able to use a 3" Aero port?I wouldn't a 3" is only ~7 square inches of port area, a 4" is even on the small side.
