What is the actual lifetime anyways, 3 years?  rofl
Video cards? Mobo's IDK? I have some that are 8+ years that I know of  that I can provide pics smile.png
  • Replies 78.9k
  • Views 4m
  • jonbearsmt
    jonbearsmt
Lasting and wanting to last are very different things.
Just saying msi mobo's aint that bad really..Most I have has been overclocked..Not really bad for the price.
Well only free if you are what they call a VIP, rofl.  Traveling a lot and buying a business class seat has WAY more perks in Asia.
Did they give you your wings?
Bought a new travel belt.  Complete dork action.  Buckle has a bottle opener, philips head screw driver, two flat heads, and box ends for 6,8,10,12,14mm and 1/4,3/8,7/16,1/2,5/8"
Closed you can't tell.  Also real light and packs small.
Did you get the Batman or the Superman one? Did it come with a grappling hook?
Chicken feet eh. interesting
thanks. still looking at all the options.
http://www.tomshardware.com/reviews/best-intel-amd-motherboard,3902.html
only 3 features i care about are decent voltage reg for OC, 6 sata ports, and at least 2 pci slots for xfire.
These are massively chopped down BTW. The original files are ~twice the size or so....
The table setting in Rome could use some help for sure.
Super dark. ISO was getting up there. I need to start caring less about ISO and just cope with the loss of data and work on editing the grain. Faster shutter speed to have less blur and capture motion is much needed.
Shooting full frame?
Also the lighting in the dining room did you little to no favors.
J
In case anyone else is wondering, here are the specs for the 90dolla10's"
90dolla10
Single 2
Fs: 32.5 Hz
Re: 1.4 Ohms/coil |
Qms: 6.25
Qes: .51
Qts: .47
Mms: 121g
Cms: 0.00mm/N
Sd: 310cm^2 | 310cm^2
Vas: 23.66 l
Spl: 83.3dB 1W/1m
Bl: 12.91 N/
Xmax: 21mm
Rms: 350W
Sealed box: .2-.4 cuft
Ported box: .6-1.2 cuft @ 33Hz
Sub OD: 11.000”
Cut ID: 9.250”
Mounting depth: 5.750”
Displacement: 0.06cuft
Fuck a duck
J
I think all that you see here is FF. The motorcycle shot might be from the T4i.
For people I'm usually using the 6D. It's so much better for low light.
SOOOOOO much better.
I have some really great pics with the crop too however. I just have less room for error with light.
I will see if I can find some more. I found out that durring a PC crash I lost 3-4 months of really important pictures.
I need to get archive grade DVDs ASAP and just get it done. I dont know if archive grade DVDs exist yet.
Culling and burning 200+ gigs of data isn't exactly fun.
