Warning: Cannot modify header information - headers already sent by (output started at /home/soundsol/public_html/forum/ips_kernel/classAjax.php:1) in /home/soundsol/public_html/forum/ips_kernel/classAjax.php on line 323
Warning: Cannot modify header information - headers already sent by (output started at /home/soundsol/public_html/forum/ips_kernel/classAjax.php:1) in /home/soundsol/public_html/forum/ips_kernel/classAjax.php on line 326
Warning: Cannot modify header information - headers already sent by (output started at /home/soundsol/public_html/forum/ips_kernel/classAjax.php:1) in /home/soundsol/public_html/forum/ips_kernel/classAjax.php on line 327
Warning: Cannot modify header information - headers already sent by (output started at /home/soundsol/public_html/forum/ips_kernel/classAjax.php:1) in /home/soundsol/public_html/forum/ips_kernel/classAjax.php on line 328
OBD-II scanner says the CEL on the Accent is P0301. Guess I get to play with that tomorrow.
Cylinder 1 misfire.
Hoping it's just a bad plug. We'll see...
  • Replies 78.9k
  • Views 3.6m
  • jonbearsmt
    jonbearsmt
Cylinder 1 misfire.
All plugs are normal; compression check time.
Cylinder 1 misfire.
What have you troubleshot so far?
Congrats on the awesome weight loss Matt!!!!!!
J
WXW went pretty well last night. I still have a ton of 'ring rust' to work off. Getting down to count pinfalls was a little delayed, and my positioning in the ring was a bit stiff. I just gotta loosen up and be more fluid. Hopefully this weekend in Miami I can make adjustments.
J
Cylinder 1 misfire.
Is this a COP or coil pack car?
COP
2008 Accent
Edited by Penguin4x4
Checking the compression and coils tomorrow; didn't have the tools on hand today.
on my TB  I went
Checked voltage at coil pack
checked signal at coil pack, I used a test light usually around 5v square wave so a MM usually isn't quick enough to test.
Actual spark at plug
followed up by then checking compression
Swap 1 & 2 coils, see if the miss follows.
