Vette was never Mg, had some Mg in it. Currently it is using the single largest hydroformed piece of alum in the world as part of its frame.
Cool that they implemented shape memory alloy in the venting system for the rear hatch as well. If you don't know what shape memory alloys are it is worth a google. Super fucking cool. I've been working with a few Nasa spin offs that are making a solid state airplane (ie no motors to run the wings or engine, but it will fly).
Similar in construction to a bi-metal strip like we see in turn signal flashers I assume, only with much slower expansion and contraction rates, yes?
  • Replies 78.9k
  • Views 4m
  • jonbearsmt
    jonbearsmt
All that technology on the Vette and they still use vacuum assist braking.  LOL.
GM yo!
Lets see here, company screwed up shipping on my replacement cell phone so I had to buy another to get it here for the weekend, smashed my finger open, and bent two 5/8" wrenches, a Gearwrench X beam and a Wright all before 10am.  Heck of a day so far.
Actually it is completely temperature dependent. ie, you can deform it at any rate you like but to reform you heat it to it's equilibrium temp and it snaps back rather quickly. Speed is controlled by the heating used. Super amazing to see first hand. First piece I held was about 8 years ago. Metal coupon the size of a business card and around 20ga. I bent the shit out of it. Crumpled into a ball. Then hit it with a heat gun and it flattened out PERFECTLY.
Interesting. I expected temperature fluctuations to create different final states, not a complete distortion returning to initial form based on temperatures. Seeing the linked spring was cool, but I would really dig the flat form that you saw initially. I assumed high temps would create cooling gaps and low would allow it to return to base form.
Different materials designed to do different things. Running a "heater" err voltage carrying wire along the material can steer it. ie, solid state plane flaps move either direction depending on heating or not-heating. Obviously balancing near the equilibrium is key for quick changes.
