  • Replies 78.9k
  • Views 3.6m
  • jonbearsmt
    jonbearsmt
Shit would be handy if you use a raspberry pi for stuff.
That nasty one was in the hole they said had a dead injector and they claimed to have scoped the hole, so to me that means pulling the plug, and they just put it back in seeing that nasty thing??
That plug is oil-fouled and covered in sludge. It's leaking oil by in a bad way.
No need to remove the plug. Run an inductive pickup on the plug wire or a low amp inductive in the case of a COP.
Looks like a valve stem seal, actually. It appears to be caked and fluffy on one side, which is indicative of that. When it stops firing the oil just saturates the build up.
Here's some more stuff you can read Sean:
http://linuxcommand.org/lc3_learning_the_shell.php
http://www.howtogeek.com/140679/beginner-geek-how-to-start-using-the-linux-terminal/
http://www.thegeekstuff.com/2010/11/50-linux-commands/
I can setup an account for you on a linux box if you want to try stuff out (terminal-wise).
quoted fir a later read non_mobile
You guys rock.
So ford guys. Speaking of spark plugs how often should I change them? My wife has a 96 mercury cougar xr7 (same engine as the mustang gt). It has around 120k mi on it and the only major maintenance I've done on it was the coolant/oil filter manifold gasket
That's a non-PI engine.  Same as 96-98 GTs.    If you get platinums and don't notice a miss or anything, you can get by with 100K or more.  I would change them if you haven't yet.  Do plug wires as well.
It seems to possibly burn oil not entirely sure. Oil level hasn't dropped but you can smell a burning oil smell when a.c. is on. Maybe a slow leak somewhere?
Saving for later
Yeah, I think Ford recommends them at 90K but I see platinums go way more than that.
So much work for a sled. Why all the hard work, you usually buy a new sled every other year?
Edited by dem beats
This one will have ALL the updates of the 2014 model with a fresh engine and fully fresh bearings add a better track, better shock valving, better gauges, handlebar riser, better bars, better throttle block, longer rails, bogeys, ski's etc.
I am not getting rid of this one for a long time. At some point it will be delegated to my second sled, but that'll be a while. For a backup I really prefer to have an old simple sled with a carburettor. Nothing exotic and all super EASY parts to get anywhere.
That and it will be quicker, more responsive and more fun than any sled sold in any dealer in the country. And obviously WAY cheaper to build one than to buy.
Rode my other sled 100mi yesterday otherwise the front end or engine would be back together too.
Instead, it sits in a box in the house
Looks like a start to a fun project!  :)
And Matt, it isn't work when it is fun. I NEED some garage night projects, but I shouldn't have waited so long. I didn't allocate time for a machine shop to press on bearings & do a hone, nor the powder coat which set me back 3 weeks. Otherwise she'd be nearly ready to roll.
To do list that is left:
Rivet on cooler - 1hr
Wash sled - 20m
Assemble front suspension - 1hr
Replace all bolts in rear suspension (should arrive Monday) - 30m
Install gas tank & seat - 2hr (20m if I am lucky)
Put the motor together - whopping 20 bolts or so, lol - 1hr (again 20m...)
Clean up wiring - 1hr
Install motor - 45m
Install front end and skis - 30m
