  • Replies 78.9k
  • Views 4m
  • jonbearsmt
    jonbearsmt
I want something super lightweight, AWD, V6 twin turbo, a roll cage, two seats and a steering wheel.
For now I'm having too much fun in the Miata. Low power, low cost.
Well screw you and your RWD :D
Being nimble is more fun than just RWD :D
Subie flat-12?
Thursday's are marathons.
Cute kiddo preston!!!!
J
Florida isn't much worse than WNY in the summer time. At least not where I am.
J
"you could even nickel plate your crack pipe"
ROFL
Want one of his bags now...
Fun fact: 316 Stainless forms the basis for most implantable metal objects in the medical field. The four screws in my tibia are made from it.
Good morning, view isn't so bad BUT I'd rather be looking at snow.
With that comment, I can no longer consider you an intelligent being. You must be part Eskimo.
Err, close, Viking.
Only part of SoCal looks like that. Most looks like this:
Holy shit quartz is expensive!
Did you check Silestone?
Yes  $65-$89 a square foot.
Any recommendations on some 3-4" midranges and tweeters to be run active 3 way. Midbass will be Exodus Anarchy run off axis in the doors, and mids and tweeters will be run on axis on the a-pillar.
Also willing to run a fullranger on axis to pair with the Exodus', just needs to handle ~1000+ Hz
Don't run the Exodus that high. If you run a 3 way you can get something that digs WAY lower and use a VERY cheap tweeter on the top. MOunting locations will determine all options though.
I would rather run a two way system. Let's say max budget is 160 for mids and 160 for highs as maximum budget. Is there a better option that Ex-Anarchy? They seem to be quite the performers. I can get the tweeters/FR's/whatever on axis, but the mid will be off axis. There's only so much I can do. What do you suggest Sean?
Edited by gprestonmoto
I know I mentioned a 2-way with the peerless hds tweets, but now I see you already have them according to your sig? What's wrong with that setup?
